[mapserver-users] How do a GetFeatureInfo on a group layers
Andrea Peri
aperi2007 at gmail.com
Fri Jul 27 11:39:28 PDT 2012
Hi Eichner,
thx for hint.
I try without the addition-layer.
The GetFeatureInfo now work.
But as a indesiderable secondary effect is disappeared the Group-name from
the getcapabilities.
There is some workaround to add a group-name to the getcapabilities ?
Thx,
Andrea.
2012/7/27 Eichner, Andreas - SID-NLKM <Andreas.Eichner at sid.sachsen.de>
> > I need to call for a GetFeatureInfo on a layer-group
> > (rt_cat.idcatbdfog).
> > I guess it should return identify result from every layer of
> > the group.
> MS does exactly that. Specifying a layer group in QUERY_LAYERS is
> basically equivalent to specifying every layer corresponding to that
> group.
> Simply ommit that additional layer:
> > LAYER
> > NAME "rt_cat.idcatbdfog"
> > TYPE POLYGON
> > METADATA
> > "ows_include_items" "all"
> > END
> > TEMPLATE 'void'
> > END
> > Instead it is say-ing:
> > msShapefileOpen(): Unable to access file. No (NULL) filename provided.
> > msBuildPath: Unable to access file.
> MS is somewhat confused and tries to query that layer which has no data.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120727/dc8efa59/attachment.html>
