AW: [mapserver-users] Getting an image scaled to pixels
Eichner, Andreas - SID-NLKM
Andreas.Eichner at sid.sachsen.de
Fri Mar 9 02:16:47 EST 2012
You might try:
mapserverMap.setConfigOption("MS_NONSQUARE", "YES");
this is basically what that WMS server code does to enable non-square pixels.
HTH
> -----Ursprüngliche Nachricht-----
> Von: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Stuart
> Gesendet: Freitag, 9. März 2012 01:33
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] Getting an image scaled to pixels
> Hi,
> I have a csharp application using map_script that I am using to cut up
> an ECW file into tiles for display on a Bing map. The issue I am
> having is that each tile slightly overlaps others above and below it.
> The procedure I am using is as follows:
> I load the basic map file below add the projection and units from
> within a csharp application:
> mapserverMap = new mapObj(mapOutputPath + mapFileName);
> mapserverMap.setWKTProjection("+proj=merc +a=6378137 +b=6378137
> +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null
> +no_defs ");
> mapserverMap.setSize(256, 256);
> mapserverMap.units = MS_UNITS.MS_DD ;
> I then use the csharp application to add a single RASTER layer
> layerObj layer = new layerObj(mapserverMap);
> Console.WriteLine(mapserverMap.layerorder);
> layer.name = ecwName;
> layer.type = MS_LAYER_TYPE.MS_LAYER_RASTER;
> layer.status = mapscript.MS_ON;
> layer.sizeunits = (int)MS_UNITS.MS_PIXELS;
> var extentdoubles = GetPlanExtentFromDB(ecwName,
> planConnectionString);
> layer.setExtent(extentdoubles[0], extentdoubles[1],
> extentdoubles[2], extentdoubles[3]);
> layer.data = mapOutputPath + ecwName + ".ecw";
> I have identified the issue is when for each quadKey I set the
> mapserverMap extent to the bounding box of the quadKey MapServer
> changes the latitudes of its extent to fit the map size (256 x 256)
> e.g. for quadKey 31121320312020 i set the MapServer extent to:
> maxX
> 152.95166015625
> maxY
> -30.334953881988554
> minX
> 152.9296875
> minY
> -30.353916372297036
> Then after setting the extent if I ask MapServer for its
> extent it returns:
> mapserverMap.extent
> {OSGeo.MapServer.rectObj}
> maxx: 152.95166015625
> maxy: -30.333448799017795
> minx: 152.9296875
> miny: -30.355421455267795
> Notice the Longitudes are the same but the Latitudes (minY, maxY) have
> been stretched.
> So my question is that when I set mapserverMap object to the bounding
> box I want it to be set to the latitude and longitude given and
> stretched to fit the map size (256 x 256) rather than MapServer
> modifying the latitudes to fit the map size.
> Any help would be appreciated.
> Stuart
> Here is the starting map file
> MAP
> NAME MyMap
> DEBUG ON
> IMAGECOLOR 128 155 155
> UNITS DD
> RESOLUTION 96
> TRANSPARENT OFF
> CONFIG "PROJ_LIB" "/ms4w/proj/nad/"
> CONFIG "CPL_DEBUG" "ON"
> SYMBOLSET ./etc/symbols.sym
> IMAGETYPE png
> FONTSET ./etc/fonts.txt
> END
