[mapserver-users] Run-time Substitution and Raster file problem
thomas bonfort
thomas.bonfort at gmail.com
Sat Mar 17 01:07:34 EDT 2012
first thing that comes to mind is
'fhour_validation_pattern' '^[][_a-zA-Z0-9]+$'
this should go in a VALIDATION block
VALIDATION
'fhour' '^[][_a-zA-Z0-9]+$'
END
On Sat, Mar 17, 2012 at 00:43, teknocreator <teknocreator at gmail.com> wrote:
> This is somewhat related to the post by Kathleen Hirst on Feb 27. We're
> using MapServer 6.0.1 and I'm attempting get around the fact that one isn't
> able to change the PROCESSING "BANDS=" directive via Run-time Substitution.
> I couldn't find a way to do it through modifying the URL that's passed
> either. As we don't have a many rasters in a file as Kathleen, I thought of
> splitting the bigger file up into individual rasters. Then use Run-time
> Substitution and pass in either the filename or just a piece of the file
> name to the DATA portion of the mapfile. The docs seem to indicate I should
> be able to do this. But, I get an error with each attempt. Here's what I
> tried first:
> MAP
> NAME "testgrib"
> IMAGETYPE PNG
> EXTENT -14000000 3000000 -7000000 7000000
> STATUS ON
> SIZE 2145 1377
> SHAPEPATH "../shapefiles"
> SYMBOLSET "../symbols/symbols35.sym"
> FONTSET "../fonts/fonts.list"
> DATAPATTERN "^.*$"
> IMAGECOLOR 255 255 255
> PROJECTION
> "init=epsg:3857"
> END
> WEB
> IMAGEPATH "test/img/tmp/ms_tmp/"
> IMAGEURL "http://localhost:8080/wxmap/test/img/tmp/ms_tmp/"
> METADATA
> "wms_title" "WMS Test " ## REQUIRED
> "wms_onlineresource" "http://localhost:8080/cgi-bin/mapserv?"
> ## Recommended
> "wms_srs" "ESPG:3857 EPSG:4326 EPSG:4269 EPSG:3978
> EPSG:900913" ## Recommended
> "wms_abstract" "This text describes my WMS service." ##
> Recommended
> "wms_enable_request" "*"
> "ows_sld_enable" "true"
> # testing
> "wms_feature_info_mime_type" "text/html"
> END
> END
> OUTPUTFORMAT
> NAME "png"
> DRIVER GD/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT ON
> END
> LAYER # GRIB attempt
> NAME mosaic
> STATUS ON
> TYPE RASTER
> DATA *../grib/ds_vis%fhour%.grb*
> CLASSITEM "[pixel]"
> METADATA
> "gml_include_items" "all"
> "wms_include_items" "all"
> END
> # testing
> DUMP TRUE
> HEADER "../templates/test_header.html"
> TEMPLATE "../templates/test_body.html"
> FOOTER "../templates/test_footer.html"
> PROJECTION
> "proj=lcc"
> "lat_1=25"
> "lat_2=25"
> "lat_0=0"
> "lon_0=-95"
> "x_0=0"
> "y_0=0"
> "a=6371200"
> "es=0.0"
> "+no_defs"
> END
> PROCESSING "NODATA=32129"
> PROCESSING "BANDS=01"
> PROCESSING "SCALE=0,11200"
> LABELITEM "[pixel]"
> CLASS
> NAME "< 1/4"
> EXPRESSION ([pixel] < 400 )
> STYLE
> COLOR 100 0 100
> END
> END
> END # End of mosaic layer
> END
> But this results in:
> "loadLayer(): Unknown identifier. Parsing error near (%):(line 90)
> msOutputFormatValidate():"
> I tried a few variations:
> - using RTS for the entire file name
> - specifying the entire path
> - quotes/no quotes around the full file path name (different error with
> quotes)
> to no avail. I tried others these either ended up in other errors. Pretty
> much hitting walls everywhere and winding up with some of the same
> variations. So, thought it was time to ask what I might be doing wrong or
> if this is even possible. I've used RTS successfully with Postgres/PostGIS,
> so I thought this should work as well. And it's the DATA statement where I
> thought this would most likely work.
> Appreciate any thoughts/help!
> Dave M
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Run-time-Substitution-and-Raster-file-problem-tp4626749p4626749.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
