[mapserver-users] [SOLVED] Re: Run-time Substitution and Raster
file problem
teknocreator
teknocreator at gmail.com
Sat Mar 17 19:04:03 EDT 2012
Thomas,
THANK YOU VERY MUCH! I knew the validation was important and I ran into
the situation with the points layer where I forgot to include the
validation_pattern line. But, I forgot what the error was when that
appeared last. Since I had the VALIDATION block this time (and I'm not as
well versed as I should be on regex), I didn't think to test it for a
possible problem. It's interesting, though, that a parsing error for the
'%' was tripped instead of a validation error. That's where I got turned
around in trying to solve this.
So I now have these lines in the mapfile:
Data "%file%"
VALIDATION
'file' '^.*$' #have to look into changing this to something with a bit
more checking
END
And in my OpenLayers code, just a quick test which first declares the raster
layer for the first hour (1):
wmsmap = new OpenLayers.Layer.MapServer( "GRIB TEST",
"/cgi-bin/mapserv",
{layers: "mosaic", SRS:"EPSG:3857",
map:"wxmap/glmpvis2.map",
format:'image/png', mode: "map", file: "dsvis1.grb",
transparent:true, reaspect: "true"},
{singleTile: true, ratio: 1, isBaseLayer: false, opacity:
1.0, visibility: true,
projection: new OpenLayers.Projection("EPSG:3857"), active:
false});
and then modifies the file name between dsvis1.grb and dsvis10.grb
function updateMap(){
var Fhour=getFHour(); // another function getting hour from radio
button group
var file = "dsvis" + Fhour + ".grb";
wmsmap.mergeNewParams({'file': file});
Radio buttons with the hours switch between the two and it works like a
charm!
Think I'll eventually add the default value lines too.
Again, can't thank you enough! Thanks to all who also commented!
Hopefully, this helps someone else along the way.
Dave M
View this message in context: http://osgeo-org.1560.n6.nabble.com/Run-time-Substitution-and-Raster-file-problem-tp4626749p4629087.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
