[mapserver-users] No map in preview
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Wed Mar 28 08:46:00 EDT 2012
If you are really trying to get a Geoserver instance running, I would suggest the Geoserver mailing list..
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dott. Scolavino Alessandro
Sent: Wednesday, March 28, 2012 3:22 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] No map in preview
i just finished loading in postgis the global data.
I tryed to display layer with geoserver but i see only "white" map.
It's a common problem?
If someone have 5 minutes to take a fast look on my geoserver to see if
i made a mistake or if i have to rebuild the db (maybe something went
wrong with the population i had to run it in background since it take
more than 3 days...)
i'll give the server address and login data (pvm)
thanx!!!
Ai sensi del DL 196/2003 si precisa che le informazioni contenute in questo
messaggio sono riservate ed a uso esclusivo del destinatario. Qualora il
messaggio in parola Le fosse pervenuto per errore, la Preghiamo di
eliminarlo senza copiarlo e di non inoltrarlo a terzi, dandocene gentilmente
comunicazione. Grazie.
Cordiali saluti
- ---- Dott. Alessandro Scolavino ----
- ---- http://www.webair.it ----
- ---- http://www.clerk.it ----
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
