[mapserver-users] Re: perl errorObj
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Tue May 1 13:44:42 EDT 2012
Hi Andy: We need you to create an issue here https://github.com/mapserver/mapserver/issues and we can go from there...
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Andy Colson
Sent: Tuesday, May 01, 2012 10:47 AM
To: mapserver-users
Subject: [mapserver-users] Re: perl errorObj
On 5/1/2012 8:50 AM, Andy Colson wrote:
> I have noticed a problem with the errorObj
> mapserver/mapscript/swig/perl object.
> Its treated as an array, the generated code to get the message looks
> like this:
> arg1 = (errorObj *)(argp1);
> result = (char *)(char *) ((arg1)->message); { size_t size = 2048;
> while (size && (result[size - 1] == '\0')) --size;
> ST(argvi) = SWIG_FromCharPtrAndSize(result, size); argvi++ ; }
> When I log errors:
> my $errObj = new mapscript::errorObj(); while ($errObj) { $s .=
> "ERROR: $errObj->{code}:$errObj->{message}:$errObj->{routine}<br>";
> $errObj = $errObj->next();
> I get the message, but then huge amounts of garbage data as well.
> In plmodule.i I tried to add a typemap:
> %typemap(memberout) char[ANY] {
> $result = newSVpvn($1, strlen($1));
> argvi++;
> But it doesn't seem to work, the generated code is exactly the same as
> it was before. (I'm new to mapscript and swig, so I'm just guessing)
> Any help or hints on how I might fix this?
> Thanks,
> -Andy
Ok, this works:
%typemap(out) char[ANY] {
argvi++;
I was worried about it changing too much code, but after looking at the generated mapscript_wrap.c, it looks fine by me. I also tested it on my test box and it reports errors much much better.
I'm going to put this on my live site and run it for a while.
Are there any -dev's on this list? I'm not subscribed to mapserver-dev, I'm hoping I can post this here and a dev can verify its ok and add it to plmodule.i.
Pretty please?
-Andy
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
