[mapserver-users] polygon border artifacts
Sven Geggus
lists at fuchsschwanzdomain.de
Fri May 4 06:16:28 EDT 2012
Hello,
the brilliant osm coastline tool from Jochen Topf
(http://blog.jochentopf.com/2012-04-19-more-coastlines-stuff.html)
enables for creating nice ocean or landcover polygons from
Openstreetmap data. Well, this is where my mapserver problem
starts...
For illustration of the problem I just created ocean polygons around
canary islands
http://home.geggus.net/pub/ocean-canary-islands.zip
They are in sperical mercator using a huge overlap of 30meters to
avoid artifacts.
However artifacts (which seem to depend on scale) still arise:
http://home.geggus.net/pub/ocean.png
Here is the mapfile and shp2img command I used for rendering:
shp2img -o ocean.png -m ocean.map -e -1917656.09 3248262.91 -1839384.59 3326534.41 -s 512 512
MAP
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG8
FORMATOPTION "INTERLACE=OFF"
MIMETYPE "image/png"
END
EXTENT -180 -85 180 85
IMAGECOLOR 255 0 0
WEB
METADATA
"ows_enable_request" "*"
wms_srs "EPSG:4326 EPSG:3857"
END
END
PROJECTION
"init=epsg:3857"
END
LAYER
PROCESSING "CLOSE_CONNECTION=DEFER"
NAME "ocean"
TYPE POLYGON
STATUS ON
DATA "ocean-canary-islands"
PROJECTION
"init=epsg:3857"
END
CLASS
STYLE
COLOR 128 255 255
END
END # of class
END # of layer
END
The only workaround I found so far is to use an outline:
OUTLINECOLOR 128 255 255
WIDTH 1
Is this a bug in mapserver or is there something else which I can do?
Sven
"Ich fürchte mich nicht vor der Rückkehr der Faschisten in der Maske der
Faschisten, sondern vor der Rückkehr der Faschisten in der Maske der
Demokraten" (Theodor W. Adorno)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
