[mapserver-users] Re: polygon border artifacts
Sven Geggus
lists at fuchsschwanzdomain.de
Mon May 7 14:47:20 EDT 2012
"Lime, Steve D (DNR)" <Steve.Lime at state.mn.us> wrote:
> I tried locally and it's definitely a rendering artifact related to anti-aliasing.
The artifact is getting worse in lower zoom levels (smaller islands).
I just tried a huge overlap of the polygons which made it better but
did not make it disapear also. So the workaround could be to find the
perfect combination of outlinewidth (as small as possible) and
overlap factor (also as small as possible).
> Should an outline always be drawn?
Tiled ocean polygons like I have them should be the perfect example
where an outline just does not make sense.
One would probably want to have an outline on the coastline but not
on polygon borders. Something one would need to render from a separate
linestring layer anyway.
Regards
Sven
"If you don't make lower-resolution mapping data publicly
available, there will be people with their cars and GPS
devices, driving around with their laptops" (Tim Berners-Lee)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
