[mapserver-users] Fail to build Mapscript Python with current
source
Peter Hopfgartner
peter.hopfgartner at r3-gis.com
Wed May 9 11:39:01 EDT 2012
Ok, it worked.
Thanks,
Peter
On 04/27/2012 03:22 PM, Umberto Nicoletti wrote:
> I just built it on Ubuntu 10.04 x86, perhaps you should try this build
> process:
> ./configure [your options] --enable-python-mapscript
> make
> sudo make install
> make/make install will also build and install python mapscript, no
> need to cd, swig, etc.
> Umberto
> On Fri, Apr 27, 2012 at 3:04 PM, Peter Hopfgartner
> <peter.hopfgartner at r3-gis.com <mailto:peter.hopfgartner at r3-gis.com>>
> wrote:
> I'm on a CentOS 6.2, x86_64 bit system:
> /configure --with-gd --with-zlib --with-tiff --with-agg
> --with-experimental-png --with-freetype=/usr/bin/freetype-config
> --with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config
> --with-geos=/usr/bin/geos-config --with-cairo=yes --with-proj
> --with-wfs --with-wcs --with-sos --with-wmsclient --with-wfsclient
> --with-xpm --with-postgis=/usr/bin/pg_config
> --with-mygis=/usr/bin/mysql_config
> --with-curl-config=/usr/bin/curl-config
> --with-xml2-config=/usr/bin/xml2-config
> --with-php=/usr/bin/php-config
> --with-fribidi-config=/usr/lib64/pkgconfig/fribidi.pc
> --with-fastcgi=/usr --without-pdf --without-eppl --with-threads
> --enable-debug --disable-runpath
> cd mapscript/python
> swig -python -shadow -modern -o mapscript_wrap.c ../mapscript.i
> cd ../..
> make
> cd mapscript/python
> python setup.py build
> The build fails with:
> gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall
> -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
> --param=ssp-buffer-size=4 -m64 -mtune=generic -D_GNU_SOURCE -fPIC
> -fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2
> -fexceptions -fstack-protector --param=ssp-buffer-size=4 -m64
> -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -DUSE_FASTCGI=1
> -DUSE_CAIRO=1 -DUSE_FRIBIDI=1 -DUSE_FRIBIDI2=1 -DUSE_WMS_LYR=1
> -DUSE_WFS_LYR=1 -DUSE_SOS_SVR=1 -DUSE_LIBXML2=1 -DUSE_CURL=1
> -DUSE_CURLOPT_PROXYAUTH=1 -DUSE_WCS_SVR=1 -DUSE_WFS_SVR=1
> -DUSE_WMS_SVR=1 -DUSE_POSTGIS=1 -DPOSTGIS_HAS_SERVER_VERSION=1
> -DUSE_GDAL=1 -DUSE_OGR=1 -DUSE_GEOS=1 -DUSE_THREAD=1 -DUSE_PROJ=1
> -DUSE_GD=1 -DUSE_GD_GIF=1 -DUSE_GD_PNG=1 -DUSE_GD_JPEG=1
> -DUSE_GD_WBMP=1 -DUSE_GD_FT=1 -DGD_HAS_FTEX_XSHOW=1
> -DGD_HAS_GDIMAGEGIFPTR=1 -DGD_HAS_GETBITMAPFONTS=1
> -DGD_HAS_GET_TRUE_COLOR_PIXEL=1 -DUSE_ICONV=1 -DUSE_JPEG=1
> -DUSE_GIF=1 -DUSE_PNG=1 -DUSE_ZLIB=1 -DUSE_FREETYPE=1
> -DHAVE_VSNPRINTF=1 -DNEED_STRLCPY=1 -DNEED_STRLCAT=1
> -DNEED_STRRSTR=1 -DDISABLE_CVSID=1 -I../..
> -I/usr/include/freetype2 -Irenderers/agg/include
> -I/usr/include/gdal -I/usr/include -I/usr/include/fastcgi
> -I/usr/include/libxml2 -I/usr/include/fribidi -I/usr/include/cairo
> -I/usr/include/pixman-1 -I/usr/include/libpng12
> -I/usr/include/python2.6
> -I/home/rpmbuild/tmp/mapserver-6.1.20120426 -c
> pygdioctx/pygdioctx.c -o
> build/temp.linux-x86_64-2.6/pygdioctx/pygdioctx.o
> pygdioctx/pygdioctx.c: In function ‘PyFileIfaceObj_IOCtx_GetBuf’:
> pygdioctx/pygdioctx.c:84: warning: passing argument 3 of
> ‘PyString_AsStringAndSize’ from incompatible pointer type
> /usr/include/python2.6/stringobject.h:172: note: expected
> ‘Py_ssize_t *’ but argument is of type ‘int *’
> gcc -pthread -shared build/temp.linux-x86_64-2.6/mapscript_wrap.o
> build/temp.linux-x86_64-2.6/pygdioctx/pygdioctx.o -L../../
> -L/usr/lib64 -L/usr/lib64 -L/usr/lib -L/usr/lib64
> -L/home/rpmbuild/tmp/mapserver-6.1.20120426 -lpython2.6
> -lmapserver -lfreetype -lgd -ljpeg -lpng -lz -lXpm -lX11 -lproj
> -lgif -lgdal -lpq -lcurl -lgeos_c -lpthread -lc -lfcgi -lxml2 -lm
> -lfribidi -lstdc++ -lfontconfig -lcairo -lpng12 -lmapserver -o
> build/lib.linux-x86_64-2.6/_mapscript.so
> /usr/bin/ld: cannot find -lmapserver
> collect2: ld returned 1 exit status
> error: command 'gcc' failed with exit status 1
> Anyway, there is a file libmapserver.la <http://libmapserver.la>
> in the source directory.
> What is it, that I'm mising?
> Thanks,
> Peter
> Peter Hopfgartner
> web : http://www.r3-gis.com
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
Peter Hopfgartner
R3 GIS Srl - GmbH
Via Johann Kravogl-Str. 2
I-39012 Meran/Merano (BZ)
web : www.r3-gis.com
mail : peter.hopfgartner at r3-gis.com
phone: +39 0473 494949
fax : +39 0473 069902
ATTENZIONE! Le informazioni contenute nella presente e-mail e nei documenti eventualmente allegati sono confidenziali. La loro diffusione, distribuzione e/o riproduzione da parte di terzi, senza autorizzazione del mittente è vietata e può violare il D. Lgs. 196/2003. In caso di ricezione per errore, Vogliate immediatamente informare il mittente del messaggio e distruggere la e-mail.
ACHTUNG! Die in dieser Nachricht oder in den beigelegten Dokumenten beinhalteten Informationen sind streng vertraulich. Ihre Verbreitung und/oder ihre Wiedergabe durch Dritte ist ohne Erlaubnis des Absenders verboten und verstößt gegen das Legislativdekret 196/2003. Sollten Sie diese Mitteilung irrtümlicherweise erhalten haben, bitten wir Sie uns umgehend zu informieren und anschließend die Mitteilung zu vernichten.
WARNING! This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden and could be against the law (D. Lgs. 196/2003)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120509/6e637a8d/attachment.html
