[mapserver-users] mapcache - problems on install
thomas bonfort
thomas.bonfort at gmail.com
Thu May 10 08:14:41 EDT 2012
please keep replies on the mailing list.
On Thu, May 10, 2012 at 2:07 PM, Helen San Segundo Navazo
<hsansegundo at meteo.cat> wrote:
> ok thanks, now seems that is really loaded the module. ([Thu May 10 13:21:24
> 2012] [notice] Apache/2.2.14 (Ubuntu) mod_fcgid/2.3.4 mod-mapcache/0.5-dev
> configured -- resuming normal operations)
> The documentation talks about a demo, I can't find it. I have the
> mapcache.xml file with a sample with a basic layer. Could you tell me how
> test it, the url call?
from the fine manual:
If you have not disabled the demo service, you should now have access
to it on http://myserver/mapcache/demo
replace /mapcache/ with what you've set in MapCacheAlias
thomas
> thanks again,
> Helen
> <?xml version="1.0" encoding="UTF-8"?>
> <!-- see the accompanying mapcache.xml.sample for a fully commented
> configuration file -->
> <mapcache>
> <cache name="disk" type="disk">
> <base>/tmp</base>
> <symlink_blank/>
> </cache>
> <source name="vmap0" type="wms">
> <getmap>
> <params>
> <FORMAT>image/png</FORMAT>
> <LAYERS>basic</LAYERS>
> </params>
> </getmap>
> <http>
> <url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
> </http>
> </source>
> <tileset name="test">
> <source>vmap0</source>
> <cache>disk</cache>
> <grid>WGS84</grid>
> <grid>g</grid>
> <format>PNG</format>
> <metatile>5 5</metatile>
> <metabuffer>10</metabuffer>
> <expires>3600</expires>
> </tileset>
> <default_format>JPEG</default_format>
> <service type="wms" enabled="true">
> <full_wms>assemble</full_wms>
> <resample_mode>bilinear</resample_mode>
> <format>JPEG</format>
> <maxsize>4096</maxsize>
> </service>
> <service type="wmts" enabled="true"/>
> <service type="tms" enabled="true"/>
> <service type="kml" enabled="true"/>
> <service type="gmaps" enabled="true"/>
> <service type="ve" enabled="true"/>
> <service type="demo" enabled="true"/>
> <errors>report</errors>
> <lock_dir>/tmp</lock_dir>
> </mapcache>
> El 10/05/12 12:46, thomas bonfort escribió:
>> Sorry, pressed send too fast...
>> you must use
>> <IfModule mapcache_module>
>> <Directory /path/to/directory>
>> Order Allow,Deny
>> Allow from all
>> </Directory>
>> MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"
>> </IfModule>
>> and not
>> <Location "/cgi-bin/">
>> SetEnv MAPCACHE_CONFIG_FILE
>> "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
>> </Location>
>> On Thu, May 10, 2012 at 12:43 PM, thomas bonfort
>> <thomas.bonfort at gmail.com> wrote:
>>> the instructions for running mapcache as an apache module are on the
>>> page you linked, more precisely:
>>> http://mapserver.org/trunk/mapcache/install.html#apache-module-specific-instructions
>>> thomas
>>> On Thu, May 10, 2012 at 12:33 PM, Helen San Segundo Navazo
>>>> Hi,
>>>> I'm new using mapcache. I've tried to install it following the
>>>> instructions
>>>> on http://mapserver.org/trunk/mapcache/install.html.
>>>> First
>>>> $./configure
>>>> $make
>>>> $sudo make install
>>>> and after the apache module
>>>> $sudo make install-module
>>>> $sudo ldconfig
>>>> On my httpd.conf I've added
>>>> </Location>
>>>> when I try to invoque mapcache in the apache log there is this error:
>>>> /usr/lib/cgi-bin/mapcache: line 202: cd:
>>>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/cgi: Not a
>>>> directory
>>>> gcc: mapcache.c: No such file or directory
>>>> gcc: ../lib/.libs/libmapcache.so: No such file or directoryn[Thu May 10
>>>> 11:57:23 2012] [error] [client 127.0.0.1] Premature end of script
>>>> headers:
>>>> mapcache
>>>> the directory exists and has permisions to access
>>>> Somebody knows how to solve it?
>>>> Thanks in advance,
>>>> Helen
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
