[mapserver-users] mapcache - problems on install
Helen San Segundo Navazo
hsansegundo at meteo.cat
Thu May 10 09:16:44 EDT 2012
hi,
deliberately I have not disabled the demo service, maybe in the
installation I had to put any "--with" to enable it? is there any way to
activate it?
thanks
El 10/05/12 14:14, thomas bonfort escribió:
> please keep replies on the mailing list.
> On Thu, May 10, 2012 at 2:07 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat> wrote:
>> ok thanks, now seems that is really loaded the module. ([Thu May 10 13:21:24
>> 2012] [notice] Apache/2.2.14 (Ubuntu) mod_fcgid/2.3.4 mod-mapcache/0.5-dev
>> configured -- resuming normal operations)
>> The documentation talks about a demo, I can't find it. I have the
>> mapcache.xml file with a sample with a basic layer. Could you tell me how
>> test it, the url call?
> from the fine manual:
> If you have not disabled the demo service, you should now have access
> to it on http://myserver/mapcache/demo
> replace /mapcache/ with what you've set in MapCacheAlias
> thomas
>> thanks again,
>> Helen
>> <?xml version="1.0" encoding="UTF-8"?>
>> <!-- see the accompanying mapcache.xml.sample for a fully commented
>> configuration file -->
>> <mapcache>
>> <cache name="disk" type="disk">
>> <base>/tmp</base>
>> <symlink_blank/>
>> </cache>
>> <source name="vmap0" type="wms">
>> <getmap>
>> <params>
>> <FORMAT>image/png</FORMAT>
>> <LAYERS>basic</LAYERS>
>> </params>
>> </getmap>
>> <http>
>> <url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
>> </http>
>> </source>
>> <tileset name="test">
>> <source>vmap0</source>
>> <cache>disk</cache>
>> <grid>WGS84</grid>
>> <grid>g</grid>
>> <format>PNG</format>
>> <metatile>5 5</metatile>
>> <metabuffer>10</metabuffer>
>> <expires>3600</expires>
>> </tileset>
>> <default_format>JPEG</default_format>
>> <service type="wms" enabled="true">
>> <full_wms>assemble</full_wms>
>> <resample_mode>bilinear</resample_mode>
>> <format>JPEG</format>
>> <maxsize>4096</maxsize>
>> </service>
>> <service type="wmts" enabled="true"/>
>> <service type="tms" enabled="true"/>
>> <service type="kml" enabled="true"/>
>> <service type="gmaps" enabled="true"/>
>> <service type="ve" enabled="true"/>
>> <service type="demo" enabled="true"/>
>> <errors>report</errors>
>> <lock_dir>/tmp</lock_dir>
>> </mapcache>
>> El 10/05/12 12:46, thomas bonfort escribió:
>>> Sorry, pressed send too fast...
>>> you must use
>>> <IfModule mapcache_module>
>>> <Directory /path/to/directory>
>>> Order Allow,Deny
>>> Allow from all
>>> </Directory>
>>> MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"
>>> </IfModule>
>>> and not
>>> <Location "/cgi-bin/">
>>> SetEnv MAPCACHE_CONFIG_FILE
>>> "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
>>> </Location>
>>> On Thu, May 10, 2012 at 12:43 PM, thomas bonfort
>>> <thomas.bonfort at gmail.com> wrote:
>>>> the instructions for running mapcache as an apache module are on the
>>>> page you linked, more precisely:
>>>> http://mapserver.org/trunk/mapcache/install.html#apache-module-specific-instructions
>>>> thomas
>>>> On Thu, May 10, 2012 at 12:33 PM, Helen San Segundo Navazo
>>>>> Hi,
>>>>> I'm new using mapcache. I've tried to install it following the
>>>>> instructions
>>>>> on http://mapserver.org/trunk/mapcache/install.html.
>>>>> First
>>>>> $./configure
>>>>> $make
>>>>> $sudo make install
>>>>> and after the apache module
>>>>> $sudo make install-module
>>>>> $sudo ldconfig
>>>>> On my httpd.conf I've added
>>>>> </Location>
>>>>> when I try to invoque mapcache in the apache log there is this error:
>>>>> /usr/lib/cgi-bin/mapcache: line 202: cd:
>>>>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/cgi: Not a
>>>>> directory
>>>>> gcc: mapcache.c: No such file or directory
>>>>> gcc: ../lib/.libs/libmapcache.so: No such file or directoryn[Thu May 10
>>>>> 11:57:23 2012] [error] [client 127.0.0.1] Premature end of script
>>>>> headers:
>>>>> mapcache
>>>>> the directory exists and has permisions to access
>>>>> Somebody knows how to solve it?
>>>>> Thanks in advance,
>>>>> Helen
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
