[mapserver-users] mapcache - problems on install
Helen San Segundo Navazo
hsansegundo at meteo.cat
Fri May 11 03:57:52 EDT 2012
Hi Thomas,
I'm trying different calls but I'm sure I'm doing it wrong because I
can't find a description how to construct the url call with the
different params.
http://localhost/mapcache/demo?LAYERS=vmap0&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG:4326&BBOx=-180,-90,180,90&WIDTH=700&HEIGHT=500&FORMAT=image/png
What I obtain in my apache log is
permission denied: access to /mapcache/demo denied
the folders have permission for writting, I've put www-data as owner but
the result is the same
Could you help me to construct the url call if that is the problem?
My mapcache alias is:
MapCacheAlias /mapcache
"/home/curs/Dearrollo/aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
the mapcache.xml is:
<!-- see the accompanying mapcache.xml.sample for a fully commented
configuration file -->
<mapcache>
<cache name="disk" type="disk">
<base>/tmp</base>
<symlink_blank/>
</cache>
<source name="vmap0" type="wms">
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>basic</LAYERS>
</params>
</getmap>
<http>
<url>http://vmap0.tiles.osgeo.org/wms/vmap0</url>
</http>
</source>
<tileset name="test">
<source>vmap0</source>
<cache>disk</cache>
<grid>WGS84</grid>
<grid>g</grid>
<format>PNG</format>
<metatile>5 5</metatile>
<metabuffer>10</metabuffer>
<expires>3600</expires>
</tileset>
<default_format>JPEG</default_format>
<service type="wms" enabled="true">
<full_wms>assemble</full_wms>
<resample_mode>bilinear</resample_mode>
<format>JPEG</format>
<maxsize>4096</maxsize>
</service>
<service type="wmts" enabled="true"/>
<service type="tms" enabled="true"/>
<service type="kml" enabled="true"/>
<service type="gmaps" enabled="true"/>
<service type="ve" enabled="true"/>
<service type="demo" enabled="true"/>
<errors>report</errors>
<lock_dir>/tmp</lock_dir>
</mapcache>
Thanks again,
Helen
El 10/05/12 15:38, thomas bonfort escribió:
> given your configuration file, you have not disabled it. what url are
> you trying to access the demo on ?
> On Thu, May 10, 2012 at 3:16 PM, Helen San Segundo Navazo
> <hsansegundo at meteo.cat> wrote:
>> hi,
>> deliberately I have not disabled the demo service, maybe in the installation
>> I had to put any "--with" to enable it? is there any way to activate it?
>> thanks
>> El 10/05/12 14:14, thomas bonfort escribió:
>>> please keep replies on the mailing list.
>>> On Thu, May 10, 2012 at 2:07 PM, Helen San Segundo Navazo
>>>> ok thanks, now seems that is really loaded the module. ([Thu May 10
>>>> 13:21:24
>>>> 2012] [notice] Apache/2.2.14 (Ubuntu) mod_fcgid/2.3.4
>>>> mod-mapcache/0.5-dev
>>>> configured -- resuming normal operations)
>>>> The documentation talks about a demo, I can't find it. I have the
>>>> mapcache.xml file with a sample with a basic layer. Could you tell me how
>>>> test it, the url call?
>>> from the fine manual:
>>> If you have not disabled the demo service, you should now have access
>>> to it on http://myserver/mapcache/demo
>>> replace /mapcache/ with what you've set in MapCacheAlias
>>> thomas
>>>> thanks again,
>>>> Helen
>>>> <mapcache>
>>>> <base>/tmp</base>
>>>> <symlink_blank/>
>>>> </cache>
>>>> <getmap>
>>>> <params>
>>>> </params>
>>>> </getmap>
>>>> <http>
>>>> </http>
>>>> </source>
>>>> <cache>disk</cache>
>>>> <grid>WGS84</grid>
>>>> <grid>g</grid>
>>>> </tileset>
>>>> </service>
>>>> </mapcache>
>>>> El 10/05/12 12:46, thomas bonfort escribió:
>>>>> Sorry, pressed send too fast...
>>>>> you must use
>>>>> <IfModule mapcache_module>
>>>>> <Directory /path/to/directory>
>>>>> Order Allow,Deny
>>>>> Allow from all
>>>>> </Directory>
>>>>> MapCacheAlias /mapcache "/path/to/directory/mapcache.xml"
>>>>> </IfModule>
>>>>> and not
>>>>> <Location "/cgi-bin/">
>>>>> SetEnv MAPCACHE_CONFIG_FILE
>>>>> "/home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/mapcache.xml"
>>>>> </Location>
>>>>> On Thu, May 10, 2012 at 12:43 PM, thomas bonfort
>>>>> <thomas.bonfort at gmail.com> wrote:
>>>>>> the instructions for running mapcache as an apache module are on the
>>>>>> page you linked, more precisely:
>>>>>> http://mapserver.org/trunk/mapcache/install.html#apache-module-specific-instructions
>>>>>> thomas
>>>>>> On Thu, May 10, 2012 at 12:33 PM, Helen San Segundo Navazo
>>>>>>> Hi,
>>>>>>> I'm new using mapcache. I've tried to install it following the
>>>>>>> instructions
>>>>>>> on http://mapserver.org/trunk/mapcache/install.html.
>>>>>>> First
>>>>>>> $./configure
>>>>>>> $make
>>>>>>> $sudo make install
>>>>>>> and after the apache module
>>>>>>> $sudo make install-module
>>>>>>> $sudo ldconfig
>>>>>>> On my httpd.conf I've added
>>>>>>> </Location>
>>>>>>> when I try to invoque mapcache in the apache log there is this error:
>>>>>>> /usr/lib/cgi-bin/mapcache: line 202: cd:
>>>>>>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/cgi: Not
>>>>>>> a
>>>>>>> directory
>>>>>>> gcc: mapcache.c: No such file or directory
>>>>>>> gcc: ../lib/.libs/libmapcache.so: No such file or directoryn[Thu May
>>>>>>> 10
>>>>>>> 11:57:23 2012] [error] [client 127.0.0.1] Premature end of script
>>>>>>> headers:
>>>>>>> mapcache
>>>>>>> the directory exists and has permisions to access
>>>>>>> Somebody knows how to solve it?
>>>>>>> Thanks in advance,
>>>>>>> Helen
>>>>>>> _______________________________________________
>>>>>>> mapserver-users mailing list
>>>>>>> mapserver-users at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
