[mapserver-users] mapcache - problems on install
Stephen Woodbridge
woodbri at swoodbridge.com
Fri May 11 09:11:24 EDT 2012
On 5/11/2012 8:22 AM, Helen San Segundo Navazo wrote:
> Sorry for insisting but I don't understeand how mapcache works.
> When I invoke in the url http://localhost/mapcache/ apache reads the
> MapCacheAlias so it goes to the path
> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/ and read
> mapcache.xml file?
> If I invoke http://localhost/mapcache/demo what's doing? reads/create a
> demo folder inside the path
> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/ or goes
> inside the mapcache.xml to a tag with "demo" value?
> I send a jpg with my structure of folders, is missing something?
> Maybe if I understand how mapcache works I would find what's the problem.
> Thanks
In the apache config you want to specify a MapCacheAlias, this should be
to a non-existent directory as apache will use this path to handoff the
request to the mapcache service handler. For example:
MapCacheAlias /mapcache /usr/var/mapcache/mapcache.xml
When mapcache gets the handoff it reads the mapcache.xml config file
which defines the various services, grids, etc that you have configured.
If you have enabled the demo service for example:
Then mapcache will generate an html page the list the configured
services. And if you click on one of the servers like wms if you
configured that, it will generate a sample OpenLayers application
preconfigured to access that service. You can view the page source to
see how to setup OpenLayers to access that service.
HTH,
-Steve W
