[mapserver-users] mapcache - problems on install
Helen San Segundo Navazo
hsansegundo at meteo.cat
Mon May 14 03:35:57 EDT 2012
Hi ,
thanks, now it works, it was a access problem to the disk where the
folder with the mapcache.xml file was, I've changed the access to
another disk and it works perfectly.
Now I can make some tests to understand how it works.
Thanks Steve for the explanation,
Helen
El 11/05/12 15:11, Stephen Woodbridge escribió:
> On 5/11/2012 8:22 AM, Helen San Segundo Navazo wrote:
>> Sorry for insisting but I don't understeand how mapcache works.
>> When I invoke in the url http://localhost/mapcache/ apache reads the
>> MapCacheAlias so it goes to the path
>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/ and read
>> mapcache.xml file?
>> If I invoke http://localhost/mapcache/demo what's doing? reads/create a
>> demo folder inside the path
>> /home/curs/Desarrollo/Aplicaciones/mapserver-mapcache-18a50e2/ or goes
>> inside the mapcache.xml to a tag with "demo" value?
>> I send a jpg with my structure of folders, is missing something?
>> Maybe if I understand how mapcache works I would find what's the
>> problem.
>> Thanks
> In the apache config you want to specify a MapCacheAlias, this should
> be to a non-existent directory as apache will use this path to handoff
> the request to the mapcache service handler. For example:
> MapCacheAlias /mapcache /usr/var/mapcache/mapcache.xml
> When mapcache gets the handoff it reads the mapcache.xml config file
> which defines the various services, grids, etc that you have configured.
> If you have enabled the demo service for example:
> Then mapcache will generate an html page the list the configured
> services. And if you click on one of the servers like wms if you
> configured that, it will generate a sample OpenLayers application
> preconfigured to access that service. You can view the page source to
> see how to setup OpenLayers to access that service.
> HTH,
> -Steve W
> mapserver-users at lists.osgeo.org
