[mapserver-users] how to embed images in a map
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon May 14 11:40:09 EDT 2012
It the logo/graphs exist as images then you can just use symbols as annotation. How you'd do that depends on version.
In 5.6 and earlier you'd use an annotation layer:
LAYER
TYPE ANNOTATION
CLASS
TEXT ' ' # blank text
STYLE
SYMBOL 'some image file'
END
END
In 6.0+ the annotation layer above should still work but you can use LABEL styles to do the same thing when you do the polygon fills which requires one pass through the data and is more efficient:
LAYER
TYPE POLYGON
CLASS
STYLE
... # fill the polygon
END
LABEL
STYLE
END
END
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of pcreso at pcreso.com
Sent: Friday, May 11, 2012 8:55 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] how to embed images in a map
I'm trying to embed graphics in a map. A map with polygons, & each polygon has a logo or small graph to include at a specified location (point) in the output map.
Can anyone suggest the best way to do this?
The map is a WMS output layer, & ideally it should be generated as a layer in a mapfile?
I guess a CGI could use image magic to do this on top of the map image, but I'm looking for a way Mapserver could do this directly.
Thanks,
Brent Wood
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120514/33202ac1/attachment-0001.html
