[mapserver-users] error accessing PostGIS 2 layer
Puneet Kishor
punk.kish at gmail.com
Thu May 17 15:05:45 EDT 2012
I migrated my data to PostGIS 2, and now I am getting the following error (using the same mapfile as with PostGIS 1.5.3)
msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR: function
geomfromtext(unknown, integer) does not exist
LINE 1: ...e_geom FROM trees.range) a_view where the_geom && GeomFromTe...
HINT: No function matches the given name and argument types. You might need to
add explicit type casts.
The offending query in the mapfile is
DATA "the_geom FROM (SELECT gid, species_id, species_color, the_geom FROM trees.range) a_view USING UNIQUE gid USING srid=4326"
So, it seems the MapServer is using that line to construct its own query, and that query is not compliant with PostGIS 2. Suggestions?
Puneet Kishor
