[mapserver-users] error accessing PostGIS 2 layer
Puneet Kishor
punk.kish at gmail.com
Thu May 17 15:58:54 EDT 2012
On May 17, 2012, at 2:20 PM, Donald Kerr wrote:
> Run one of the ".sql" files in "\PostgreSQL\9.1\share\contrib\postgis-2.0"
> to restore legacy funtions to PostGIS 2 e.g. "legacy.sql".
> "legacy_minimal.sql" worked for me with my set up.
phew! thanks! legacy_minimal.sql did it.
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Puneet Kishor
> Sent: 17 May 2012 20:06
> To: mapserver
> Subject: [mapserver-users] error accessing PostGIS 2 layer
> I migrated my data to PostGIS 2, and now I am getting the following error
> (using the same mapfile as with PostGIS 1.5.3)
> msPostGISLayerWhichShapes(): Query error. Error executing query:
> ERROR: function
> geomfromtext(unknown, integer) does not exist
> LINE 1: ...e_geom FROM trees.range) a_view where the_geom &&
> GeomFromTe...
> HINT: No function matches the given name and argument types. You
> might need to
> add explicit type casts.
> The offending query in the mapfile is
> DATA "the_geom FROM (SELECT gid, species_id, species_color, the_geom
> FROM trees.range) a_view USING UNIQUE gid USING srid=4326"
> So, it seems the MapServer is using that line to construct its own query,
> and that query is not compliant with PostGIS 2. Suggestions?
> Puneet Kishor_______________________________________________
> mapserver-users at lists.osgeo.org
