[mapserver-users] convert projection from UTM to WGS84 using proj
Jørn Vegard Røsnes
jorn at spacetec.no
Mon May 21 04:53:49 EDT 2012
cs2cs is a part of proj
http://trac.osgeo.org/proj/
Transforms from one projection to another.
I think it's just a matter of getting the projection parameters right.
Maybe this tool can help you, I just googled it (via http://gis.stackexchange.com/questions/7608/shapefile-prj-to-postgis-srid-lookup-table):
http://prj2epsg.org/search
kind regards
Jørn-Vegard Røsnes
----- Original Message -----
> From: "Murat Beyhan" <beyhan at deprem.gov.tr>
> To: "Jørn Vegard Røsnes" <jorn at spacetec.no>
> Cc: "mapserver-users" <mapserver-users at lists.osgeo.org>
> Sent: Monday, 21 May, 2012 9:57:53 AM
> Subject: Re: [mapserver-users] convert projection from UTM to WGS84 using proj
> Hi,
> is cs2cs a tool for converting shape data and
> are there any example for this purpose
> actually I added +x_0=500000. to ogr2ogr command but doesn't cahaged
> the
> result :(
> On Fri, 2012-05-18 at 14:00 +0200, Jørn Vegard Røsnes wrote:
> > Hi,
> > I lost your previous email, so this is just by memory.
> > I'm not an projection expert, but here we go :-)
> > Regarding 3dg offset:
> > In your .prj file there is an false easting=500000, so maybe it
> > helps adding +x_0=500000.
> > http://proj.maptools.org/gen_parms.html
> > Se also +towgs84 in the same link and .prj file, and adjust
> > accordingly.
> > Maybe a shot in the dark because 3dg = 333958,33m (40 075,017km /
> > 360dg).
> > I think you're near the solution.
> > See also
> > http://spatialreference.org/
> > http://spatialreference.org/ref/epsg/4230/
> > kind regards
> > Jørn-Vegard Røsnes
> > > From: "Jørn Vegard Røsnes" <jorn at spacetec.no>
> > > To: "Murat Beyhan" <beyhan at deprem.gov.tr>
> > > Sent: Wednesday, 16 May, 2012 11:21:22 AM
> > > WGS84 using proj
> > > Hi,
> > > maybe something like this:
> > > ogr2ogr -s_srs epsg:4230 -t_srs epsg:4326 <dest shapefile>
> > > <source
> > > shapefile>
> > > http://www.gdal.org/ogr2ogr.html
> > > kind regards
> > > Jørn-Vegard Røsnes
> > > > To: "mapserver-users" <mapserver-users at lists.osgeo.org>
> > > > Sent: Wednesday, 16 May, 2012 10:41:39 AM
> > > > Subject: [mapserver-users] convert projection from UTM to WGS84
> > > > using proj
> > > > Dear friends,
> > > > I'm sorry, I'm not good at GIS applications but I wondering
> > > > about
> > > > conversion between various projection or datum of the data
> > > > files.
> > > > data.shp data.shx data.dbf and data.prj files are available.
> > > > shpdump data.shp gives following
> > > > Shape:0 (ArcZ) nVertices=4, nParts=1
> > > > Bounds:( 513275.786, 4006041.761, 0, 0)
> > > > to ( 513345.812, 4006078.182, 0, 0)
> > > > ( 513275.786, 4006078.182, 0, 0) Ring
> > > > ( 513301.130, 4006064.906, 0, 0)
> > > > ( 513321.636, 4006053.249, 0, 0)
> > > > ( 513345.812, 4006041.761, 0, 0)
> > > > data.prj as follows
> > > > PROJCS["(UTM)Universal Transvers Merkator 3�",GEOGCS["EUROPEAN
> > > > 1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.00000000,297.00000000],
> > > > TOWGS84[-87.00000000,-98.00000000,-121.00000000,0.00000000,0.00000000,0.00000000,0.00000000]],
> > > > PRIMEM["Greenwich",0.00000000],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],
> > > > PARAMETER["SCALE_FACTOR",1.00000000],PARAMETER["CENTRAL_MERIDIAN",36.00000000],PARAMETER["LATITUDE_OF_ORIGIN",0.00000000],
> > > > PARAMETER["FALSE_EASTING",500000.00000000],PARAMETER["FALSE_NORTHING",0.00000000],UNIT["meter",1.00000000]]
> > > > using these data How to convert a file which is created using
> > > > european_datum_1950 to WGS84 (World Geodetic System 1984)
> > > > or where I have to start to understand these method of
> > > > applications
> > > > using PROJ4.
> > > > Thanks
> > > > muratB
> > > > This message has been scanned for viruses and
> > > > dangerous content by MailScanner, and is
> > > > believed to be clean.
> > > > _______________________________________________
> > > > mapserver-users mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > CONFIDENTIALITY
> > This e-mail and any attachment contain KONGSBERG information which
> > may be
> > proprietary, confidential or subject to export regulations, and is
> > only meant
> > for the intended recipient(s). Any disclosure, copying,
> > distribution or use is
> > prohibited, if not otherwise explicitly agreed with KONGSBERG. If
> > received in
> > error, please delete it immediately from your system and notify the
> > sender
> > properly.
> Murat BEYHAN
> Jeofizik Y.Müh.
> T.C. Başbakanlık
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
CONFIDENTIALITY
This e-mail and any attachment contain KONGSBERG information which may be
proprietary, confidential or subject to export regulations, and is only meant
for the intended recipient(s). Any disclosure, copying, distribution or use is
prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
error, please delete it immediately from your system and notify the sender
properly.
