[mapserver-users] convert projection from UTM to WGS84 using proj
Murat Beyhan
beyhan at deprem.gov.tr
Wed May 23 04:17:40 EDT 2012
Dear friends,
I have solved my problem using ogr gui tool easily and thank you for
your interest.
Regards...
On Mon, 2012-05-21 at 09:43 +0000, Rahkonen Jukka wrote:
> Hi,
> Ogr2ogr is your tool for converting shapefiles. There must be something wrong in the predefined EPSG parameteres. Give projections as +proj strings and you will have a full control over what happens. An example about conversion from EPSG:2393 into EPSG:3067
> ogr2ogr -f "ESRI Shapefile" -s_srs "+proj=tmerc +lat_0=0 +lon_0=27 +k=1 +x_0=3500000 +y_0=0 +ellps=intl +towgs84=-96.0617,-82.4278,-121.7535,4.80107,0.34543,-1.37646,1.4964 +units=m" -t_srs "+proj=utm +zone=35 +ellps=GRS80 +units=m +towgs84=0,0,0,0 +no_defs" target.shp original.shp
> Mapserver takes the parameters from the text file named "epsg" and it is easy to edit by hand. However, ogr2ogr does not use that file. Therefore you did not see any difference after your edits.
> -Jukka Rahkonen-
> Murat Beyhan wrote:
> > Hi,
> > is cs2cs a tool for converting shape data and
> are there any example for this purpose
> actually I added +x_0=500000. to ogr2ogr command but doesn't cahaged the
> result :(
> On Fri, 2012-05-18 at 14:00 +0200, Jørn Vegard Røsnes wrote:
> > Hi,
> > I lost your previous email, so this is just by memory.
> > I'm not an projection expert, but here we go :-)
> > Regarding 3dg offset:
> > In your .prj file there is an false easting=500000, so maybe it helps adding +x_0=500000.
> > http://proj.maptools.org/gen_parms.html
> > Se also +towgs84 in the same link and .prj file, and adjust accordingly.
> > Maybe a shot in the dark because 3dg = 333958,33m (40 075,017km / 360dg).
> > I think you're near the solution.
> > See also
> > http://spatialreference.org/
> > http://spatialreference.org/ref/epsg/4230/
> > kind regards
> > Jørn-Vegard Røsnes
> > ----- Original Message -----
> > > From: "Jørn Vegard Røsnes" <jorn at spacetec.no>
> > > To: "Murat Beyhan" <beyhan at deprem.gov.tr>
> > > Cc: "mapserver-users" <mapserver-users at lists.osgeo.org>
> > > Sent: Wednesday, 16 May, 2012 11:21:22 AM
> > > Subject: Re: [mapserver-users] convert projection from UTM to WGS84 using proj
> > > Hi,
> > > maybe something like this:
> > > ogr2ogr -s_srs epsg:4230 -t_srs epsg:4326 <dest shapefile> <source
> > > shapefile>
> > > http://www.gdal.org/ogr2ogr.html
> > > kind regards
> > > Jørn-Vegard Røsnes
> > > > From: "Murat Beyhan" <beyhan at deprem.gov.tr>
> > > > To: "mapserver-users" <mapserver-users at lists.osgeo.org>
> > > > Sent: Wednesday, 16 May, 2012 10:41:39 AM
> > > > Subject: [mapserver-users] convert projection from UTM to WGS84
> > > > using proj
> > > > Dear friends,
> > > > I'm sorry, I'm not good at GIS applications but I wondering about
> > > > conversion between various projection or datum of the data files.
> > > > data.shp data.shx data.dbf and data.prj files are available.
> > > > shpdump data.shp gives following
> > > > Shape:0 (ArcZ) nVertices=4, nParts=1
> > > > Bounds:( 513275.786, 4006041.761, 0, 0)
> > > > to ( 513345.812, 4006078.182, 0, 0)
> > > > ( 513275.786, 4006078.182, 0, 0) Ring
> > > > ( 513301.130, 4006064.906, 0, 0)
> > > > ( 513321.636, 4006053.249, 0, 0)
> > > > ( 513345.812, 4006041.761, 0, 0)
> > > > data.prj as follows
> > > > PROJCS["(UTM)Universal Transvers Merkator 3�",GEOGCS["EUROPEAN
> > > > 1950",DATUM["European_Datum_1950",SPHEROID["International",6378388.00000000,297.00000000],
> > > > TOWGS84[-87.00000000,-98.00000000,-121.00000000,0.00000000,0.00000000,0.00000000,0.00000000]],
> > > > PRIMEM["Greenwich",0.00000000],UNIT["Degree",0.01745329],AUTHORITY["EPSG","4230"]],PROJECTION["TRANSVERSE_MERCATOR"],
> > > > PARAMETER["SCALE_FACTOR",1.00000000],PARAMETER["CENTRAL_MERIDIAN",36.00000000],PARAMETER["LATITUDE_OF_ORIGIN",0.00000000],
> > > > PARAMETER["FALSE_EASTING",500000.00000000],PARAMETER["FALSE_NORTHING",0.00000000],UNIT["meter",1.00000000]]
> > > > using these data How to convert a file which is created using
> > > > european_datum_1950 to WGS84 (World Geodetic System 1984)
> > > > or where I have to start to understand these method of applications
> > > > using PROJ4.
> > > > Thanks
> > > > muratB
> > > > This message has been scanned for viruses and
> > > > dangerous content by MailScanner, and is
> > > > believed to be clean.
> > > > _______________________________________________
> > > > mapserver-users mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > CONFIDENTIALITY
> > This e-mail and any attachment contain KONGSBERG information which may be
> > proprietary, confidential or subject to export regulations, and is only meant
> > for the intended recipient(s). Any disclosure, copying, distribution or use is
> > prohibited, if not otherwise explicitly agreed with KONGSBERG. If received in
> > error, please delete it immediately from your system and notify the sender
> > properly.
> Murat BEYHAN
> Jeofizik Y.Müh.
> T.C. Başbakanlık
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Lodumlu/ANKARA
