[mapserver-users] Postgres/Postgis additonal variable request
Heiko Schroeter
schroete at iup.physik.uni-bremen.de
Wed May 23 08:34:50 EDT 2012
Hello,
i need to select data from an array inside a table. I cannot get mapserver to
create the correct select request statement.
The problem i recognize is that the "unique" key is inserted in the Mapserver
select request as ".... key from , ....".
Basically i need something like this:
select coords as geom, color from produkt_db using unique date using srid=-1
What do i have to do to request additional values in the mapserver DATA Line
besides the "geom" and the "unique key" variables which are inserted
automatically ?
Thanks and Regards
Heiko
The Mapserver Postgres Docs says this:
..... The form of DATA is “[geometry_column] from [table_name|sql_subquery]
using unique [unique_key] using srid=[spatial_reference_id]”......
s/w versions:
Postgres 9.1
MapServer version 6.0.1
OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Requesting the database manually this select statement works fine:
select "datum", encode(ST_AsBinary(ST_Force_2D("rechteck"),'NDR'),'hex') as
geom, HWFarbe[40] as farbe from produkt_20 where rechteck &&
GeomFromText('POLYGON((-269.711846318036 -138.025613660619,-269.711846318036
138.025613660619,269.711846318036 138.025613660619,269.711846318036
-138.025613660619,-269.711846318036 -138.025613660619))',-1) and
((date_trunc('minute', datum) >= '2006-08-02 00:00:00' AND
date_trunc('minute', datum) <= '2006-08-02 23:59:00'));
And this mapfile results in the query below (closest i could get to the
working select statement above):
<snip>
LAYER
EXTENT -180 -90 180 90
CONNECTIONTYPE POSTGIS
NAME "PRODLAYER"
PROCESSING "CLOSE_CONNECTION=DEFER"
OPACITY 100
STATUS ON
VALIDATION
"produkt" "^[a-zA-Z0-9_]+$"
"hoehe" "^[0-9]+$"
END
METADATA
"wms_timeextent" "1970-01-01 00:00/2030-12-31 24:00"
"wms_timeitem" "datum" #column in postgis table of type timestamp
"wms_timedefault" "2007-12-10 00:00/2007-12-11 24:00"
"wms_title" "%produkt%"
"wms_srs" "init=epsg:4326"
END
PROJECTION
"init=epsg:4326"
END
CONNECTION "user={97C559B77AE23F6F} password={53E7F71F40F9BD02}
dbname={5A08CA2830DE1001} host=dw"
DATA "rechteck from , HWFarbe[%hoehe%] as farbe from %produkt% using unique
datum using srid=-1"
TYPE POLYGON
SIZEUNITS meters
CLASS
NAME "produkt_total_class"
STYLE
OUTLINECOLOR 0 0 0
COLOR [farbe]
END
END
END # Layer
<snap>
Mapserver Error Log:
<snip>
[Wed May 23 14:10:15 2012].482261 msPostGISLayerWhichShapes(): Query error.
Error (FEHLER: Syntaxfehler bei ","
LINE 1: ...2D("rechteck"),'NDR'),'hex') as geom,"datum" from , HWFarbe[...
select
"datum","farbe",encode(ST_AsBinary(ST_Force_2D("rechteck"),'NDR'),'hex') as
geom,"datum" from , HWFarbe[40] as farbe from produkt_20 where rechteck &&
[Wed May 23 14:10:15 2012].482294 msDrawMap(): Image handling error. Failed to
draw layer named 'PRODLAYER'.
<snap>
