[mapserver-users] Fwd: collect value from xml and show it in html template
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Mon May 28 17:11:37 PDT 2012
You might be be able to use AJAX to access the XML and parse it using JavaScript. That's one idea. You could also consider offline parsing of the XML. For example a cron job could be run every so often to extract the necessary value into a text file. You could then include that value into template or even mapfile content. If the XML data doesn't change that often then this might be a good option.
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of gianluca massei [agr.gianluca.massei at gmail.com]
Sent: Monday, May 28, 2012 3:30 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Fwd: collect value from xml and show it in html template
I'm trying to use MODIS WMS in my study purpose mapweb. The images are
"time support" but I don't know the last day that MODIS image is
available. This data is the default value in xml definition file
(http://neowms.sci.gsfc.nasa.gov/wms/wms?version=1.1.1&service=WMS&request=GetCapabilities).
I'd like collect the last data value available and use it for print the
data that I'm using for my web application. Without this value, I can
show the map but I don't know it's acquiring data.
Thanks G M
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
