[mapserver-users] On a wms-request force the add of a layer when another layer is requested
Andrea Peri
aperi2007 at gmail.com
Tue May 29 09:57:07 PDT 2012
Hi Jukka,
The REQUIRES element work this mode:
Layer2 is visible only when also Layer1 is in the request
So a request like this:
...&layers=layer1,layer2
is visible layer1 + layer2
In a request like this:
...&layers=layer2
nothing is visible.
Instead I need this other possibility:
on a request
...&layers=layer2
the result visible is:
Layer1 + Layer2
Thx,
Andrea.
2012/5/29 Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> Hi,
> Layer2 should come always together with Layer1 If you put this line in
> Layer2 definitions
> REQUIRES "[Layer1]"
> Without testing I cannot guarantee that I remember it right. For me the
> logic of keyword "REQUIRES" feels reversed because my brain says that
> Layer2 is rather required by Layer1. Perhaps native English speakers think
> it is OK and explicit like it is now.
> -Jukka Rahkonen-
> Andrea Peri wrote:
> Hi,
> I'm using MapServer trunk version.
> Thx to Stephen Woodbridge response,
> (http://lists.osgeo.org/pipermail/mapserver-users/2012-May/072326.html)
> I'm able to avoid the use of a single layer of a group.
> Now I have another (perhaps) more complex question.
> I need to realize a map file with a configuration that
> when the Layer1 is ligh-on from the user (using a wms request), the map
> response will contains also another "Layer2".
> But I cannot use the "group" element because the two layers (Layer1 and
> layer2) are not in the same group.
> They are in two distinct and different groups.
> So I guess to allow this should be available a command like "requires",
> but that force the light-on of Layer2 instead of deny the light-on of the
> layer1.
> Is this available on mapServer ?
> thx,
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120529/0c2ed872/attachment.html>
