[mapserver-users] MapServer and shapefile
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Tue Oct 2 00:05:48 PDT 2012
Because you talk about base layer I think that you are perhaps going to show your map in OpenLayers. If that is the case then the answer is yes and this OpenLayers example shows how it can be done.
http://dev.openlayers.org/releases/OpenLayers-2.12/examples/wms-untiled.html
On the Mapserver side you must configure a WMS layer that is using shapefile as input data.
http://www.mapserver.org/ogc/wms_server.html
-Jukka Rahkonen-
Fabio Brolese wrote:
> Hello everybody,
> after a long search on Google I'm here to ask you if it's possible to use a shapefile as base layer.
> Everything I found was on exporting to shapefile or drawing objects from shapefile but nothing saying that I can >use it as base layer.
Can anyone help me?
TIA
Fabio
