[mapserver-users] text size from field but with an expression
Andrea Peri
aperi2007 at gmail.com
Sun Oct 7 12:57:03 PDT 2012
unfortunately using the spatialite DB the sintax you suggest is not allowed.
It allow
DATA 'mytable'
but don't allow
DATA "the_geom from (select id,the_geom,field1+10 as field1, field2
from mytable) as foo using unique id using srid=xxx"
I don't know if this miss is a lack of feature or a bug.
Andrea.
2012/10/4 Andrea Peri <aperi2007 at gmail.com>
> ok, thx.
> Infact I'm using spatialite db.
> So I hope to have success to support this sintax.
> Now I'm try.
> Thx.
> 2012/10/4 thomas bonfort <thomas.bonfort at gmail.com>
>> On Thu, Oct 4, 2012 at 10:04 AM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> > Hi,
>> > I have a label with the size from a field of attributes.
>> > But I need to change this size adding always a costant factor.
>> > I need someting like:
>> > LABEL
>> > SIZE expression([field1]+10)
>> > ANGLE [field2]
>> > END
>> > This seem don't allowed.
>> > Is this right ?
>> correct. if you are using a db backend, you can let the db do this for
>> you:
>> > Thx,
>> > Andrea Peri
>> > qwerty àèìòù
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121007/85befdb9/attachment.html>
