[mapserver-users] text size from field but with an expression
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sun Oct 7 15:11:12 PDT 2012
This works for sure for me:
DATA "select geometry,osm_id,amenity,aeroway, name from osm_polygon where amenity is not null or aeroway='apron'"
Perhaps you do not need anything else than
DATA "select id,the_geom,field1+10 as field1, field2 from mytable"
-Jukka Rahkonen-
Andrea Peri wrote:
> Hi,
> unfortunately using the spatialite DB the sintax you suggest is not allowed.
> It allow
> DATA 'mytable'
> but don't allow
> DATA "the_geom from (select id,the_geom,field1+10 as field1, field2
from mytable) as foo using unique id using srid=xxx"
> I don't know if this miss is a lack of feature or a bug.
Andrea.
2012/10/4 Andrea Peri <aperi2007 at gmail.com<mailto:aperi2007 at gmail.com>>
ok, thx.
Infact I'm using spatialite db.
So I hope to have success to support this sintax.
Now I'm try.
Thx.
2012/10/4 thomas bonfort <thomas.bonfort at gmail.com<mailto:thomas.bonfort at gmail.com>>
On Thu, Oct 4, 2012 at 10:04 AM, Andrea Peri <aperi2007 at gmail.com<mailto:aperi2007 at gmail.com>> wrote:
> Hi,
> I have a label with the size from a field of attributes.
> But I need to change this size adding always a costant factor.
> I need someting like:
> LABEL
> SIZE expression([field1]+10)
> ANGLE [field2]
> END
> This seem don't allowed.
> Is this right ?
correct. if you are using a db backend, you can let the db do this for you:
> Thx,
> Andrea Peri
> qwerty àèìòù
> mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Andrea Peri
qwerty àèìòù
Andrea Peri
qwerty àèìòù
