[mapserver-users] setting up a map file for mapcache - assistance with polygon labeling
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Oct 11 12:46:09 PDT 2012
Hello,
I am trying to set up mapfile for tiling on mapcache. I have a couple issues:
First,
I came across documentation stating that I should use PROCESSING "LABEL_NO_CLIP=ON" so that labels continue across tiles. Unfortunately one of the side effects that I noticed with LABEL_NO_CLIP is that the density of labels is decreased dramatically. On one map file with LABEL_NO_CLIP=OFF every parcel on a block is labeled, however if I turn LABEL_NO_CLIP=ON then only two of the 10 parcels are labeled. (could this be a bug?)
Second,
Is it possible to repeat labels on a polygon so that there is at least one label a 500 by 500 box?
If anyone could give me any tips on preparing polygon labels that will be tiled let me know.
Thank You
Mark Volz
GIS Specialist
