[mapserver-users] TinyOWS wrong call in OpenLayers - 'InvalidParameterValue' - XML request isn't valid
Olivier Courtin olivier.courtin at gmail.com
Tue Oct 16 09:14:52 PDT 2012
Hi Riccardo,
Well if everything work's fine except OpenLayers,
maybe it's an OpenLayers configuration issue...
TinyOWS debug tools are really unix based,
so could be a bit painfull under Win32...
I suggest you to begin to follow step by step
this tutorial, to check that everything work as expected:
http://mapserver.org/trunk/tinyows/openlayershowtobasic.html
Nota: With OpenLayers client retrieving data as GeoJson
is a better idea than as GML.
HTH,
Olivier
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121016/7c8e6029/attachment.htm>
More information about the MapServer-users mailing list
