[mapserver-users] TinyOWS wrong call in OpenLayers - 'InvalidParameterValue' - XML request isn't valid
Riccardo Gaeta
riccardog79 at gmail.com
Wed Oct 17 05:09:53 PDT 2012
Thanks Olivier. It doesn't work anyway. I can see the layer "base" but not
my tinyows layer...
I post for you:
1) my config.xml file:
<tinyows online_resource="http://127.0.0.1:8080/cgi-bin/tinyows.exe"
schema_dir="C:\PostgreSQL\EnterpriseDB-ApachePHP\tinyows\schema\"
log="C:\PostgreSQL\EnterpriseDB-ApachePHP\apache\logs\tinyows.log"
log_level="7">
<pg host="localhost" user="***" password="***" dbname="***" port="5432"/>
<metadata name="TinyOWS Server" title="TinyOWS Server - Demo Service" />
<layer retrievable="1"
ns_prefix="tows"
ns_uri="http://www.tinyows.org"
name="france"
title="France Departments Boundaries" />
</tinyows>
2) the tinyows.log error:
[ERROR] Element '{http://www.w3.org/2001/XMLSchema}import': Failed to
locate a schema at location '
http://127.0.0.1:8080/cgi-bin/tinyows.exe?service=WFS&request=DescribeFeatureType&version=1.0.0'.
Skipping the import.
[ERROR] Element '{http://www.opengis.net/wfs}GetFeature': No matching
global declaration available for the validation root.
3) the result of the call '
seems to work. I get:
<xs:schema xmlns:tows="http://www.tinyows.org" xmlns:ogc="
http://www.opengis.net/ogc"xmlns:xs="http://www.w3.org/2001/XMLSchema
" xmlns="http://www.w3.org/2001/XMLSchema" xmlns:gml="
http://www.opengis.net/gml"targetNamespace="http://www.tinyows.org
" elementFormDefault="qualified" version="1.0">
<xs:import namespace="http://www.opengis.net/gml" schemaLocation="
http://schemas.opengis.net/gml/2.1.2/feature.xsd"/>
<xs:element name="france" type="tows:franceType"
substitutionGroup="gml:_Feature"/>
<xs:complexType name="franceType">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="id_geofla" type="decimal" nillable="true"
minOccurs="0" maxOccurs="1"/>
<xs:element name="code_chf_l" type="string" nillable="true"
<xs:element name="nom_chf_l" type="string" nillable="true"
<xs:element name="x_chf_lieu" type="int" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="y_chf_lieu" type="int" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="x_centroid" type="int" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="y_centroid" type="int" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="nom_dept" type="string" nillable="true"
<xs:element name="code_reg" type="string" nillable="true"
<xs:element name="nom_region" type="string" nillable="true"
<xs:element name="code_dept" type="string" nillable="true"
<xs:element name="geom" type="gml:MultiPolygonPropertyType"
nillable="true" minOccurs="0" maxOccurs="1"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
4) Finally the error on apache error.log:
[client 127.0.0.1] error : No such file or directory\r, referer:
http://localhost:8080/tinyows.html
[error] [client 127.0.0.1] I/O warning : failed to load external entity "
http://127.0.0.1:8080/cgi-bin/tinyows.exe?service=WFS&request=DescribeFeatureType&version=1.0.0"\r,
referer: http://localhost:8080/tinyows.html
On QGIS I'm able to load the layer without problem, as before.
Thanks again,
Riccardo
P.S.:sorry Olivier maybe before I've answered just to you...
2012/10/16 Olivier Courtin <olivier.courtin at gmail.com>
> Hi Riccardo,
> Well if everything work's fine except OpenLayers,
> maybe it's an OpenLayers configuration issue...
> TinyOWS debug tools are really unix based,
> so could be a bit painfull under Win32...
> I suggest you to begin to follow step by step
> this tutorial, to check that everything work as expected:
> http://mapserver.org/trunk/tinyows/openlayershowtobasic.html
> Nota: With OpenLayers client retrieving data as GeoJson
> is a better idea than as GML.
> HTH,
> Olivier
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121017/a14003c4/attachment.html>
