[mapserver-users] undefined reference to `__sync_sub_and_fetch_4'
Umberto Nicoletti
umberto.nicoletti at gmail.com
Thu Oct 18 07:56:38 PDT 2012
Could you try to compile the following code:
/* begin */
int
main ()
int x;__sync_fetch_and_add(&x,1);
return 0;
/* end */
How to compile: save to test.c and then run:
gcc test.c
Best regards,
Umberto
On Thu, Oct 18, 2012 at 1:01 PM, Thiago Tiedtke dos Reis
<tiedtke at gmail.com>wrote:
> Hi,
> I having the same problem when trying to compile the mapserver with
> msys/mingw under Ms windows 7 32bit.
> Regards,
> Em 17/10/2012 14:32, "Umberto Nicoletti" <umberto.nicoletti at gmail.com>
> escreveu:
> David,
>> what is your os/platform?
>> On Oct 17, 2012 6:30 PM, "David Quinn" <daithiquinn at gmail.com> wrote:
>> > Hello List,
>> > I'm getting the following error when I try to compile
>> mapserver-6.2.0-rc1
>> > $make
>> > /bin/sh ./libtool --mode=link --tag=CXX g++ -rpath /home/david/lib
>> > shp2img.lo libmapserver.la -o shp2img
>> > libtool: link: g++ .libs/shp2img.o -o .libs/shp2img
>> > ./.libs/libmapserver.so -L/home/david/lib /home/david/lib/libgd.so
>> > -L/usr/lib /home/david/lib/libproj.so /home/david/lib/libgdal.so
>> > -L/home/david -L/usr/kerberos/lib /usr/lib/libexpat.so
>> > /home/david/lib/libgif.so /home/david/lib/libcurl.so
>> > /home/david/lib/libgeos_c.so /home/david/lib/libgeos.so
>> > /home/david/lib/libxml2.so /home/david/lib/libfreetype.so
>> > -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err -lcairo -lXpm -lfontconfig
>> > -lpng12 -lsqlite3 -lodbc -lodbcinst -ljpeg -lpng -lpq -lpthread -lSM
>> > -lICE -lX11 -lidn -lldap -lrt -lssl -lcrypto -ldl -lz -lbz2 -Wl,-rpath
>> > -Wl,/home/david/lib
>> > ./.libs/libmapserver.so: undefined reference to `__sync_sub_and_fetch_4'
>> > collect2: ld returned 1 exit status
>> > make: *** [shp2img] Error 1
>> > I originally got this error message: /usr/bin/ld: warning:
>> > libcurl.so.3, needed by /home/david/lib/libgdal.so, may conflict with
>> > libcurl.so.4 so I installed gdal from trunk, and reinstalled freetype,
>> > giflib and libcurl
>> > I've also attached the output from my ./configure command:
>> > -------------- Compiler Info -------------
>> > C compiler: gcc -g -Wall
>> -Wdeclaration-after-statement
>> > C++ compiler: g++ -g -Wall
>> > Debug: -g
>> > Generic NINT:
>> > -------------- Renderer Settings ---------
>> > OpenGL support:
>> > zlib support:
>> > png support: -DUSE_PNG
>> > gif support: -DUSE_GIF
>> > jpeg support: -DUSE_JPEG
>> > freetype support: -DUSE_FREETYPE
>> > iconv support: -DUSE_ICONV
>> > AGG support: internal
>> > GD support: -DUSE_GD -DUSE_GD_PNG -DUSE_GD_JPEG
>> -DUSE_GD_GIF
>> > Cairo (SVG,PDF) support: -DUSE_CAIRO
>> > Cairo SVG symbol support:
>> > KML support: -DUSE_KML
>> > -------------- Support Libraries ---------
>> > Proj.4 support: -DUSE_PROJ
>> > Proj Fastpaths:
>> > Libxml2 support: -DUSE_LIBXML2
>> > FriBidi support:
>> > Curl support: -DUSE_CURL -DUSE_CURLOPT_PROXYAUTH
>> > FastCGI support:
>> > Exempi support:
>> > Threading support:
>> > GEOS support: -DUSE_GEOS
>> > XML Mapfile support:
>> > XSLT support:
>> > EXSLT support:
>> > -------------- Data Format Drivers -------
>> > PostGIS support: -DUSE_POSTGIS -DPOSTGIS_HAS_SERVER_VERSION
>> > ArcSDE support:
>> > OGR support: -DUSE_OGR
>> > GDAL support: -DUSE_GDAL
>> > Oracle Spatial support:
>> > -------------- OGC Services --------------
>> > WMS Server: -DUSE_WMS_SVR
>> > WMS Client: -DUSE_WMS_LYR
>> > WFS Server: -DUSE_WFS_SVR
>> > WFS Client: -DUSE_WFS_LYR
>> > WCS Server: -DUSE_WCS_SVR
>> > SOS Server:
>> > -------------- MapScript -----------------
>> > PHP MapScript: yes
>> > Python MapScript: no
>> > -David
>> > _______________________________________________
>> > mapserver-users mailing list
>> > mapserver-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121018/88de76dc/attachment.htm>
More information about the MapServer-users
