[mapserver-users] libpng error: image size exceeds user limits in IHDR
Andrea Peri
aperi2007 at gmail.com
Tue Oct 23 11:47:11 PDT 2012
Perhaps something correlated to the bit of colors ? The GIF is a 256 only
color format.
Instead the png could be to million colors.
I use this :
IMAGETYPE PNG8
OUTPUTFORMAT
NAME "AGGA"
DRIVER AGG/PNG
MIMETYPE "image/png"
IMAGEMODE RGBA # need RGBA to have the transparent
EXTENSION "png"
FORMATOPTION "GAMMA=1.0"
FORMATOPTION "INTERLACE=true"
FORMATOPTION "QUANTIZE_DITHER=OFF"
FORMATOPTION "COMPRESSION=6" # Compression: 0=no compression, 9=best,
6=default compression
FORMATOPTION "QUANTIZE_FORCE=ON"
FORMATOPTION "QUANTIZE_COLORS=256"
TRANSPARENT ON
END
The most important thing is that the
force the mapserver to give only the 256 better colors.
If the question is on the 256 color or million color perhaps this could
work.
Andrea.
2012/10/23 Alessandro Pasotti <apasotti at gmail.com>
> hi All,
> I'm in big troubles with a wierd error in python mapscript, the log
> reports: libpng error: image size exceeds user limits in IHDR
> image size is 256x256... using gif instead of png shows no errors (as
> expected)... any idea?
> the very same piece of code run fine on my testing machine, the error
> is only on production server.
> Mapserver version is 6.0.3, python 2.5 and the code is basically a
> wrapper to WMS service, the error appears just after
> map.OWSDispatch( req )
> output format is set to AGGA:
> OUTPUTFORMAT
> NAME 'AGGA'
> DRIVER AGG/PNG
> IMAGEMODE RGBA
> END
> the complete call is
> ?LAYERS=track_1&TRANSPARENT=TRUE&FORMAT=image%2Fpng%3B%20mode%3D24bit&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A900913&BBOX=0.0,5009377.0857,2504688.54285,7514065.62855&WIDTH=256&HEIGHT=256
> It seems like wrong HEIGHT and WIDTH are passed to the raster buffer,
> I've already checked that the map object has the right size after
> OWSDispatch.
> Thanks in advance for any help!
> Alessandro Pasotti
> w3: www.itopen.it
> mapserver-users at lists.osgeo.org
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121023/44cdbf6b/attachment.html>
