[mapserver-users] Retrieve in template the coord pixel of click
Andrea Peri
aperi2007 at gmail.com
Wed Oct 24 01:27:42 PDT 2012
I found a workaround.
I can invoke directly the parameter name as report on docs:
http://mapserver.org/trunk/mapfile/template.html#template
>[post or get variable name], [post or get variable name_esc]> The contents
of any variables passed to the MapServe
But I notice this solution is Case-Sensitive.
Instead the parameters in a querystring are not case-sensitive.
This is a problem because is not so sure that an user could use this
parameter as
I&J instead of i&j.
Andrea.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121024/b0be44ba/attachment.htm>
More information about the MapServer-users
