[mapserver-users] WMS server error. Invalid layer(s) given in the LAYERS parameter.
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Oct 25 14:02:07 PDT 2012
Perhaps you have not added
"ows_enable_request" "*"
into your mapfile. Search and read the migration guide if this happens to be the reason for the trouble.
Mapserver web site should be updated at least.
-Jukka Rahkonen-
Mike Stoddart wrote:
> I'm using MapServer 6.0.1 on Fedora 16 and I'm having a weird layer issue. We're trying to port our application from MapServer 5 -> 6 and we're seeing the error:
> I can re-create the problem using Python MapScript and an example map file from the MapServer website. The map file is:
MAP
NAME "sample"
STATUS ON
SIZE 600 400
EXTENT -180 -90 180 90
UNITS DD
IMAGECOLOR 255 255 255
FONTSET "/opt/test/conf/fonts.list"
# Start of web interface definition
WEB
IMAGEPATH "/opt/test/static/ms_tmp"
IMAGEURL "/media/ms_tmp/"
END # WEB
# Start of layer definitions
LAYER
NAME 'inline_circles'
TYPE CIRCLE
STATUS on
FEATURE
POINTS
74.01 -53.8
110.7 -22.16
END
END
CLASS
STYLE
COLOR 0 0 255
END
END
END
END # MAP
If I use the following Python:
import mapscript
f = "<path to map file>"
m = mapscript.mapObj(f)
r = mapscript.OWSRequest()
r.setParameter('LAYERS', 'inline_circle')
m.loadOWSParameters(r)
I get:
<ServiceExceptionReport version="1.1.1">
<ServiceException code="LayerNotDefined">
msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
</ServiceException>
</ServiceExceptionReport>
File "<stdin>", line 1, in <module>
File "/usr/lib64/python2.7/site-packages/mapscript.py", line 1623, in loadOWSParameters
def loadOWSParameters(*args): return _mapscript.mapObj_loadOWSParameters(*args)
_mapscript.MapServerError: msWMSLoadGetMapParams(): WMS server error. Invalid layer(s) given in the LAYERS parameter.
So it doesn't think the layer exists. If I check the layer's status:
m.getLayer(0).status
0
The layer is disabled? So I'm assuming something is amiss in my map file but I just can't see it. Am I missing something obvious?
Thanks
Mike
