[mapserver-users] gdal20dev.dll not found - Solved
Sowmya Tiramdasu
stiramdasu at lp360.com
Fri Oct 26 07:30:23 PDT 2012
I got this one solved. Just wanted to post the solution . It could be
helpful to anyone else.
I compiled gdal library again from the sources. There is a visual studio
solution available for gdal so I compiled it using visual studio and it
generated the gdal20dev.dll and my problem got solved.
Now I could successfully get the mapserver compiled from the sources on a
64bit Windows 7 Machine.
Thanks ,
Sowmya.
_______________________________
Sowmya Tiramdasu
GeoCue Corporation
9668 Madison Blvd., Suite 202
Madison, AL 35758
(256) 461-8289 Telephone
(256) 461-8249 Fax
<http://www.geocue.com> www.geocue.com
Integrating the Geospatial Workplace...
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sowmya
Tiramdasu
Sent: Friday, October 26, 2012 7:58 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] gdal20dev.dll not found
I am trying to compile mapserver from the sources using the Build kits. I
could get the required exes and libs generated but when I do
> mapserv -v operation it is looking for gdal20dev.dll which is not
available on my machine.
Can anyone please tell me where I can find this dll or how I can make the
mapserver to look for other flavours of gdal dlls which I have ( liek
gdal19.dll etc)
Thanks in advance,
Sowmya Tiramdasu.
Sowmya Tiramdasu
GeoCue Corporation
Madison, AL 35758
(256) 461-8249 Fax
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121026/bd778b13/attachment-0001.html>
