[mapserver-users] mapserver and php
Stephen Woodbridge
woodbri at swoodbridge.com
Sat Oct 27 17:17:21 PDT 2012
On 10/27/2012 8:15 PM, Stephen Woodbridge wrote:
> On 10/27/2012 7:40 PM, Vince Miller wrote:
>> I'm trying to get Mapserver 6.0.3 running with Apache and PHP under
>> Ubuntu 12.04. The Apache/Mapserver connection works, as does the
>> apache PHP connection, but Mapserver won't talk to PHP. I try
>> compiling Mapserver
>> --with-php=/usr/local/src/mapserver-6.0.3/mapscript/php and it fails
>> to find php_config.h or php_version.h, neither of which can be found
>> anywhere in the php files, let alone in mapscript/php. What am I
>> doing wrong here?
>> Thank youy very much for your help.
> A couple of things:
> 1. make sure you instal the php5-dev package
> sudo apt-get install php5-dev
> 2. --with-php=/usr
> this should point to where you have installed php on your system,
> NOT to the mapscript/php
need more help? google: install php mapscript ubuntu
will probably get all you need, if not ask.
-Steve W
