[mapserver-users] Strategies for displaying a temporary Postgres table
David Quinn
daithiquinn at gmail.com
Tue Oct 30 12:28:32 PDT 2012
Thanks Bob - I did not realize I could substitute the table name. That
solves the problem.
I'm using SELECT ST_Extent(geom) FROM mytable to get the bounding box using
PostGIS, and then using the results from that with MAPEXT.
-David
On Tue, Oct 30, 2012 at 2:44 PM, Basques, Bob (CI-StPaul) <
bob.basques at ci.stpaul.mn.us> wrote:
> You can use something like this in the LAYER block for the POSTGIS
> connection:****
> DATA "the_geom FROM %YourTableName% USING SRID=200068"****
> FILTER " acqtime > '%time_idx1%' AND acqtime <'%time_idx2%' "**
> The items surrounded with “%” are populated from the same named parameters
> in the calling Link.****
> http://Sitename/mapserver-cgi/mapfilename.map?time_idx1=BeginTimeValue&time_idx2=EndTimeValue&YourTableName=Your_table. . . .
> more info is here:****
> http://mapserver.org/cgi/runsub.html****
> bobb****
> *From:* David Quinn [mailto:daithiquinn at gmail.com]
> *Sent:* Tuesday, October 30, 2012 1:41 PM
> *To:* Basques, Bob (CI-StPaul)
> *Subject:* RE: [mapserver-users] Strategies for displaying a temporary
> Postgres table****
> I do know the table name beforehand - but how do I pass that (and the
> extents) in as a parameter?****
> -David****
> If you know the table name beforehand, you can pass that into the Mapfile
> as well as an additional parameter.****
> Bobb****
> *Sent:* Tuesday, October 30, 2012 1:33 PM
> *Subject:* Re: [mapserver-users] Strategies for displaying a temporary
> Postgres table****
> Bobb,****
> Sorry - I don't quite follow. How do I update the table name?****
> Thanks,****
> David****
> On Tue, Oct 30, 2012 at 2:30 PM, Basques, Bob (CI-StPaul) <
> bob.basques at ci.stpaul.mn.us> wrote:****
> David,****
> You can grab the extents from the MAPFILE call and insert them into the
> DATA call in the mapfile.****
> Bobb****
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *David Quinn
> *Sent:* Tuesday, October 30, 2012 1:27 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Strategies for displaying a temporary
> Postgres table****
> Hi List,****
> I am exploring how to show the results of a pgRouting shortest path query.
> One suggestion is to create a temporary table (
> http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/MapServer.html).
> One way I thought of doing this is to write a mapfile using php with DATA
> supplied with the appropriate temporary table name and EXTENT with the
> extent of the table. I'm not sure if this approach is a good practice, or
> whether I should be using a different method.****
> Thanks,****
> David****
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121030/a3a9f353/attachment.html>
