[mapserver-users] MapServer 6.2.0 beta2 release - WFS getcapabilities problem
thomas bonfort
thomas.bonfort at gmail.com
Wed Sep 26 07:06:07 PDT 2012
On Wed, Sep 26, 2012 at 3:56 PM, Helen San Segundo Navazo
<hsansegundo at meteo.cat> wrote:
> Hi, I've download the mapserver-msautotest-970b31e and I've done the
> getcapabilities request to the wfs_simple.map in both versions of mapserver
> and the result is the same, with the 6.0.2 I have no problem but with
> mapserver 6.2 beta2, wfs 1.1.0 not works.
to clarify, on your setup, getcapabilities on wfs_simple.map fails
with 6.2 and succeeds in 6.0.2 ?
> this is the mapservers installation I have:
> MapServer version 6.2.0-beta2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO
> SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=ORACLESPATIAL
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> MapServer version 6.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
> SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV
> SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=ORACLESPATIAL INPUT=OGR
> El 26/09/12 14:21, thomas bonfort escribió:
>> Sorry, not able to test this as the mapfile is missing some includes,
>> and I am not setup to test oracle connections. please test this with a
>> shapefile mapfile, and/or give more info as to what output you're
>> getting on the failed request (no output at all, error message, ... ?)
>> On Wed, Sep 26, 2012 at 2:07 PM, Helen San Segundo Navazo
>>> Hi,
>>> I send you the map file.
>>> Thanks,
>>> Helen
>>> El 26/09/12 13:49, thomas bonfort escribió:
>>>> Helen,
>>>> can you provide the mapfile you are using that exhibits this? Our
>>>> tests on wfs capabilities show no abnormal failures between 1.0.0 and
>>>> 1.1.0 getcaps requests:
>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs11_cap.xml
>>>> https://github.com/mapserver/msautotest/blob/branch-6-2/wxs/expected/wfs_cap.xml
>>>> thomas
>>>> On Wed, Sep 26, 2012 at 1:32 PM, Helen San Segundo Navazo
>>>>> Hi to all,
>>>>> I've created some wfs on mapserver 6.0.2 and all of them work perfectly
>>>>> with
>>>>> the different requests and wfs versions 1.0.0 and 1.1.0.
>>>>> I've pass from 6.0.2 to 6.2.0 beta2 release to solve the style request
>>>>> problem with raster data sources and now I have problems with the wfs
>>>>> getcapabilities request with 1.1.0 version.
>>>>> With this 1.1.0 version I can't do getcapabilities request, I have no
>>>>> response but there is no problem with describefeaturetype or getfeature
>>>>> requests.
>>>>> With the same 6.2.0 beta2 if I use wfs version= 1.0.0 there is no
>>>>> problem.
>>>>> Anybody knows wich can be the problem?
>>>>> Thanks
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
