[mapserver-users] WFS in MapServer?
    Saka Royban
    sakaroyban at yahoo.com
    Tue Apr 30 05:53:24 PDT 2013
Thanks Jukka for your help
I wasn't asking a specific question but a general question. To make it short, my real question was that "Does mapserver performs reliably in providing WFS server so that we can rely on GML responses of WFS server?"
To explain my situation, i'm using data from MS101 demo. I'm making a query client-side to get features where "NA2DESC = 'Canada'", as you can see in following link:
http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/ms101/htdocs/wfs.map&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&TYPENAME=continents&MAXFEATURES=100&Filter=<Filter><PropertyIsEqualTo><PropertyName>NA2DESC</PropertyName><Literal>Canada</Literal></PropertyIsEqualTo></Filter>
When i perform the same query in ArcGIS, i get more than 5000 records selected. But, when  i use above link, i get 23 records in received GML (which is blow 100 threshold) [ i use QGIS for viewing GML]
This is my mapfile :
MAP
  NAME           "MS101"
  EXTENT        -180 -90 180 90 # Geographic
  SIZE           800 400
  IMAGECOLOR     128 128 255
  SHAPEPATH '../data'
    FONTSET '../fonts/fonts.list'
  IMAGETYPE png24
    OUTPUTFORMAT
        NAME "OGRGML"
        DRIVER "OGR/GML"
        FORMATOPTION "STORAGE=filesystem"
        FORMATOPTION "FORM=multipart"
        FORMATOPTION "FILENAME=result.gml"
    END
  PROJECTION
        "init=epsg:4326"
    END
    WEB
        METADATA
            wfs_title "WFS101"
            wfs_onlineresource "http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/ms101/htdocs/wfs.map&"
            wfs_srs "EPSG:4326"
            wfs_enable_request "*"
              wfs_maxfeatures "100"
        END
    END
  LAYER # World polygon classified by continents begins here
    NAME         continents
    DATA         'shapefile/Countries_area'
    STATUS       on
    TYPE         POLYGON
    PROJECTION
      "init=epsg:4326"
    END
        METADATA
            wfs_title "continents"
            #wms_enable_request "*"
            gml_include_items "all"
            gml_featureid        "ID"
            #gml_geometries     "geom"
            #gml_geom_type        "polygon"
        END
    CLASSITEM    'NA3DESC'
    LABELITEM    'NA3DESC'
    CLASS
      NAME       'Africa'
      EXPRESSION 'Africa'
      STYLE
        COLOR    255 128 128
      END
      LABEL
        COLOR    64 64 64
        OUTLINECOLOR 212 212 212
        TYPE     TRUETYPE
        FONT     vera_sans-bold-italic
        SIZE     12
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'Antarctica'
      EXPRESSION /Antarctic./ #'Antarctic Area'
      STYLE
        COLOR    128 255 128
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'Asia'
      EXPRESSION 'Asia'
      STYLE
        COLOR    0 0 255
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION auto
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'Oceania'
      EXPRESSION /Australia*/ #'Australian Area'
      STYLE
        COLOR    255 255 128
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'Europe'
      EXPRESSION 'Europe'
      STYLE
        COLOR    255 128 255
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'North America'
      EXPRESSION 'North America'
      STYLE
        COLOR    128 255 255
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
    CLASS
      NAME       'South America'
      EXPRESSION 'South America'
      STYLE
        COLOR    255 192 96
      END
      LABEL
        COLOR    64 64 64
        TYPE     TRUETYPE
        SIZE     10
        ANTIALIAS TRUE
        POSITION CC
        PARTIALS FALSE
        MINDISTANCE 250
        BUFFER   4
      END
    END
  END # World polygon classified by continents ends here
Any help would be really appreciated.
Regards.
 From: Rahkonen Jukka <jukka.rahkonen at mmmtike.fi>
To: 'Saka Royban' <sakaroyban at yahoo.com>; 'MapServer' <mapserver-users at lists.osgeo.org>
Sent: Monday, April 29, 2013 3:20 PM
Subject: Re: [mapserver-users] WFS in MapServer?
No, it may just be that your question is a bit hard to answer. Could you give us a bit more information about your data, mapfile and WFS request you have been using?   Ogrinfo report about the datasource, layer definitions from the mapfile and at least the extents from the map level are needed.  A hand written WFS url is most useful but if you can capture with Firebug or something what Openlayers is really sending if will do as well.  Set also DEBUG 5 and CONFIG "CPL_DEBUG" "ON" into your layer setting in the mapfile and study what you get into the ms_errorfile.
I do not believe that Mapserver WFS is 100% compliant but it may still be good enough. Speed depends usually much more on how the data in the backend is arranged than on the server.
Here you can get some OpenStreetMap poinst from a very weak server
http://hip.latuviitta.org/cgi-bin/ms_ows?service=wfs&version=1.0.0&request=getfeature&typename=osm_pisteet&maxfeatures=1000
and this will give you some areas
http://hip.latuviitta.org/cgi-bin/ms_ows?service=wfs&version=1.0.0&request=getfeature&typename=osm_alueet&maxfeatures=1000
There is also another member in the Mapserver family,  TinyOWS, which has cleared all the CITE tests for WFS and which can do also WFS-T. However, it works only with PostGIS.
-Jukka Rahkonen-
Saka Royban wrote
Have i banned by mailing list users or admin?
To: MapServer <mapserver-users at lists.osgeo.org>
Sent: Saturday, April 27, 2013 5:46 PM
Subject: [mapserver-users] WFS in MapServer?
Hi all
As a newbie, i've got confused. I've set up a WFS server with mapserver and then get some queries, Once by URL and another time by using OpenLayers. But the result GML contains just part of data that it must. (I've set MaxFeatures to 100 but GML contains less than 100 while there is more than 100 features in compliance with my query)
Then i got to page 560 of mapserver documentation, which says some statistics about WFS OGC test suites. So now, my question is that "Is MapServer doing totally well in providing WFS? Is it in full compliance with OGC WFS specification?" or we should not expectmuch from mapserver WFS server.
If not so, i'm looking for some real implementation of mapserver WMS and WFS to see the speed and other things. Could u provide me some links?
Thanks in advance
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130430/6b5a4f7c/attachment.htm>
More information about the MapServer-users
