[mapserver-users] drawing multiple layers from postgis
Michael McInnis
mmcinnis59 at msn.com
Fri Aug 9 08:40:28 PDT 2013
I'm pretty sure that END is correctly ending the Symbol Clause.
The odd thing about this is I can draw all four layers if I call them separately but when I try to call them through php only numbers 1 and 3 work. All layers were generated the same way inpostgresql/postgis (see sql below).
I'm going to regenerate layers 2 and 4 just in case but I think it's a problem with php/ms_script.
// All these
work
http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business1.map&layers=business_rd1%20states&mode=map
http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business2.map&layers=business_rd2%20states&mode=map
http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business3.map&layers=business_rd3%20states&mode=map
http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business4.map&layers=business_rd4%20states&mode=map
// Half of
these work
http://mapserver0/business.php?num=1 works
http://mapserver0/business.php?num=2 not
http://mapserver0/business.php?num=3 works
http://mapserver0/business.php?num=4 not
// All these
work
// Half of
these work
// Create rounded
lat lon table
Select count(*), round(cast(ST_X(geom) as numeric),2) as lon,
round(cast(ST_Y(geom) as numeric),2) as lat
Into
business_rd2
From
business_loc
Group By round(cast(ST_X(geom) as numeric),2), round(cast(ST_Y(geom) as numeric),2)
Order By count Desc
// Add Geometry
Alter Table business_rd2 Add
Column geom geometry(POINT,4326);
Update
business_rd2 Set geom =
ST_SetSRID(ST_MakePoint(lon,lat),4326);
Create Index indx_business_rd2_geom On
business_rd2 Using GIST(geom);
// Now add a
primary key named id to enable mapserver drawing
Alter Table
business_rd2 Add Column
id BIGSERIAL Primary Key;
> Date: Fri, 9 Aug 2013 12:23:52 +0200
> Subject: Re: [mapserver-users] drawing multiple layers from postgis
> From: thomas.bonfort at gmail.com
> To: mmcinnis59 at msn.com
> On 8 August 2013 20:16, Michael McInnis <mmcinnis59 at msn.com> wrote:
> > Hopefully, this is an easy one.
> > I'm trying to build a scale sensitive .map file using points from postgis.
> > I can successfully draw the shapefile states with a single points layer from
> > postgis.
> > However, if I add an additional points layer and attempt to draw it the
> > layer comes up blank.
> > If I remove the leading postgis points layer from the .map file the new
> > points layer will now display.
> > IE I can only draw the first occurrence of a postgis layer in the map file.
> > How do you define multiple postgis layers so that you can pick and choose
> > layers for display?
> > LAYER
> > NAME states
> > DATA STATES
> > STATUS ON
> > TYPE Polygon
> > CLASS
> > OUTLINECOLOR 255 255 255
> > COLOR 155 155 155
> > END # Class
> > END # Layer
> > LAYER
> > CONNECTIONTYPE POSTGIS
> > NAME business_rd2
> > CONNECTION "host=localhost dbname=Business user=postgres
> > password=xxxx port=5432"
> > PROCESSING "CLOSE_CONNECTION=DEFER"
> > DATA "geom From business_rd2 as rd2 using unique id using srid=4326"
> > #MINSCALE 100000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 255 0 0
> > END
> this END is bogus
> > END # Class
> > END # Layer
> > LAYER
> > NAME business_rd1
> > DATA "geom From business_rd1 as rd1 using unique id using srid=4326"
> > #MINSCALE 100000
> > STATUS ON
> > TYPE POINT
> > CLASS
> > SYMBOL 'circle'
> > SIZE 2
> > COLOR 255 0 0
> > END
> this one to
> > END # Class
> > END # Layer
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130809/adeae762/attachment-0001.html>
