[mapserver-users] drawing multiple layers from postgis
thomas bonfort
thomas.bonfort at gmail.com
Fri Aug 9 09:16:49 PDT 2013
You could also have removed the END I pointed out in my first answer.
The mapfile parser has a lot of legacy :)
On 9 August 2013 18:15, Michael McInnis <mmcinnis59 at msn.com> wrote:
> Nice work Thomas! That's got it.
> http://localhost/cgi-bin/mapserv?map=/media/D_Drive/www/gis/business.map&layers=business_rd4%20states&mode=map
> Now I can call any of the 4 from one .map file.
> Now I just need to figure out how to call a specific layer via a .php file.
> Thanks a lot, very subtle change there Adding STYLE in front of SYMBOL.
> Michael McInnis 6033 44th Ave. N.E. Seattle, WA 98115 206 517-4701
>> From: bob.basques at ci.stpaul.mn.us
>> CC: mapserver-users at lists.osgeo.org
>> Date: Fri, 9 Aug 2013 16:02:31 +0000
>> Subject: Re: [mapserver-users] drawing multiple layers from postgis
>> Thomas,
>> Oh man!! That's a subtle piece of info, any reason the END can't be left
>> in there as a default somehow or at least ignored inside of the STYLE block,
>> I can see this coming back to bite folks over time with the two different
>> formats for SYMBOL/(and sometime END) combos.
>> Bobb
>> -----Original Message-----
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
>> Sent: Friday, August 09, 2013 10:58 AM
>> To: Michael McInnis
>> Cc: mapserver-users at lists.osgeo.org
>> third time's a charm :)
>> LAYER
>> NAME business_rd1
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=localhost dbname=Business user=postgres password=xxxx
>> port=5432"
>> DATA "geom From business_rd1 as rd1 using unique id using srid=4326"
>> PROCESSING "CLOSE_CONNECTION=DEFER"
>> #MINSCALE 10000000
>> STATUS ON
>> TYPE POINT
>> CLASS
>> STYLE
>> SYMBOL 'circle'
>> SIZE 2
>> COLOR 255 0 0
>> END #Style
>> END # Class
>> END # Layer
>> symbol takes an END when you're defining a symbol , not when referencing
>> it in a style.
>> On 9 August 2013 17:55, Michael McInnis <mmcinnis59 at msn.com> wrote:
>> > Thomas,
>> > Here is my complete map file when all the postgis layers are combined.
>> > Like I said, I can call all of these layers if I put just one layer in
>> > a .map file but can't get it to work with more than one.
>> > Thanks!
>> > MAP
>> > DEBUG 5
>> > CONFIG "MS_ERRORFILE" "/media/D_Drive/www/gis/logs/error_file.log"
>> > EXTENT -126 25 -64 50
>> > #EXTENT -123 47 -122 48
>> > IMAGECOLOR 153 179 204
>> > IMAGETYPE PNG24
>> > SHAPEPATH data/
>> > FONTSET data/fonts/fonts.list
>> > SIZE 1000 500
>> > #SIZE 800 800
>> > #SCALEDENOM 50000
>> > UNITS DD
>> > PROJECTION
>> > "+proj=longlat +ellps=WGS84"
>> > END
>> > OUTPUTFORMAT
>> > NAME png
>> > DRIVER "AGG/PNG"
>> > MIMETYPE "image/png"
>> > IMAGEMODE RGBA
>> > EXTENSION "png"
>> > END
>> > WEB
>> > IMAGEPATH "/media/D_Drive/www/gis/tmp/"
>> > IMAGEURL "gis/tmp/"
>> > END
>> > SYMBOL
>> > NAME "circle"
>> > TYPE ELLIPSE
>> > FILLED TRUE
>> > POINTS 1 1 END
>> > END
>> > LAYER
>> > NAME states
>> > DATA STATES
>> > STATUS ON
>> > TYPE Polygon
>> > CLASS
>> > OUTLINECOLOR 255 255 255
>> > COLOR 155 155 155
>> > END # Class
>> > END # Layer
>> > LAYER
>> > NAME business_rd1
>> > password=xxxx port=5432"
>> > #MINSCALE 10000000
>> > STATUS ON
>> > TYPE POINT
>> > CLASS
>> > SYMBOL 'circle'
>> > SIZE 2
>> > COLOR 255 0 0
>> > END
>> > END # Class
>> > END # Layer
>> > LAYER
>> > NAME business_rd2
>> > password=xxxxx port=5432"
>> > DATA "geom From business_rd2 as rd2 using unique id using srid=4326"
>> > #MINSCALE 1000000
>> > STATUS ON
>> > TYPE POINT
>> > CLASS
>> > SYMBOL 'circle'
>> > SIZE 2
>> > COLOR 0 255 0
>> > END
>> > END # Class
>> > END # Layer
>> > LAYER
>> > NAME business_rd3
>> > DATA "geom From business_rd3 as rd3 using unique id using srid=4326"
>> > #MINSCALE 100000
>> > STATUS ON
>> > TYPE POINT
>> > CLASS
>> > SYMBOL 'circle'
>> > SIZE 2
>> > COLOR 0 0 255
>> > END
>> > END # Class
>> > END # Layer
>> > LAYER
>> > NAME business_rd4
>> > DATA "geom From business_rd4 as rd4 using unique id using srid=4326"
>> > #MINSCALE 10000
>> > STATUS ON
>> > TYPE POINT
>> > CLASS
>> > SYMBOL 'circle'
>> > SIZE 2
>> > COLOR 255 0 255
>> > END
>> > END # Class
>> > END # Layer
>> > END # Map File
>> >> Date: Fri, 9 Aug 2013 17:44:02 +0200
>> >> From: thomas.bonfort at gmail.com
>> >> To: mmcinnis59 at msn.com
>> >> https://github.com/mapserver/mapserver/issues/2922
>> >> On 9 August 2013 17:40, Michael McInnis <mmcinnis59 at msn.com> wrote:
>> >> > I'm pretty sure that END is correctly ending the Symbol Clause.
>> >> > The odd thing about this is I can draw all four layers if I call
>> >> > them separately but when I try to call them through php only
>> >> > numbers 1 and 3 work. All layers were generated the same way in
>> >> > postgresql/postgis (see sql below).
>> >> > I'm going to regenerate layers 2 and 4 just in case but I think
>> >> > it's a problem with php/ms_script.
>> >> > // All these work
>> >> > s1.map&layers=business_rd1%20states&mode=map
>> >> > s2.map&layers=business_rd2%20states&mode=map
>> >> > s3.map&layers=business_rd3%20states&mode=map
>> >> > s4.map&layers=business_rd4%20states&mode=map
>> >> > // Half of these work
>> >> > http://mapserver0/business.php?num=1 works
>> >> > http://mapserver0/business.php?num=2 not
>> >> > http://mapserver0/business.php?num=3 works
>> >> > http://mapserver0/business.php?num=4 not
>> >> > // All these work
>> >> > // Create rounded lat lon table
>> >> > Select count(*), round(cast(ST_X(geom) as numeric),2) as lon,
>> >> > round(cast(ST_Y(geom) as numeric),2) as lat
>> >> > Into business_rd2
>> >> > From business_loc
>> >> > Group By round(cast(ST_X(geom) as numeric),2),
>> >> > numeric),2)
>> >> > Order By count Desc
>> >> > // Add Geometry
>> >> > Alter Table business_rd2 Add Column geom geometry(POINT,4326);
>> >> > Update business_rd2 Set geom =
>> >> > ST_SetSRID(ST_MakePoint(lon,lat),4326);
>> >> > Create Index indx_business_rd2_geom On business_rd2 Using
>> >> > GIST(geom);
>> >> > // Now add a primary key named id to enable mapserver drawing
>> >> > Alter Table business_rd2 Add Column id BIGSERIAL Primary Key;
>> >> >> Date: Fri, 9 Aug 2013 12:23:52 +0200
>> >> >> postgis
>> >> >> On 8 August 2013 20:16, Michael McInnis <mmcinnis59 at msn.com> wrote:
>> >> >> > Hopefully, this is an easy one.
>> >> >> > I'm trying to build a scale sensitive .map file using points
>> >> >> > from postgis.
>> >> >> > I can successfully draw the shapefile states with a single
>> >> >> > points layer from postgis.
>> >> >> > However, if I add an additional points layer and attempt to draw
>> >> >> > it the layer comes up blank.
>> >> >> > If I remove the leading postgis points layer from the .map file
>> >> >> > the new points layer will now display.
>> >> >> > IE I can only draw the first occurrence of a postgis layer in
>> >> >> > the map file.
>> >> >> > How do you define multiple postgis layers so that you can pick
>> >> >> > and choose layers for display?
>> >> >> > LAYER
>> >> >> > NAME states
>> >> >> > DATA STATES
>> >> >> > STATUS ON
>> >> >> > TYPE Polygon
>> >> >> > CLASS
>> >> >> > COLOR 155 155 155
>> >> >> > END # Class
>> >> >> > END # Layer
>> >> >> > LAYER
>> >> >> > NAME business_rd2
>> >> >> > srid=4326"
>> >> >> > #MINSCALE 100000
>> >> >> > STATUS ON
>> >> >> > TYPE POINT
>> >> >> > CLASS
>> >> >> > SYMBOL 'circle'
>> >> >> > SIZE 2
>> >> >> > COLOR 255 0 0
>> >> >> > END
>> >> >> this END is bogus
>> >> >> > END # Class
>> >> >> > END # Layer
>> >> >> > LAYER
>> >> >> > NAME business_rd1
>> >> >> > srid=4326"
>> >> >> > #MINSCALE 100000
>> >> >> > STATUS ON
>> >> >> > TYPE POINT
>> >> >> > CLASS
>> >> >> > SYMBOL 'circle'
>> >> >> > SIZE 2
>> >> >> > COLOR 255 0 0
>> >> >> > END
>> >> >> this one to
>> >> >> > END # Class
>> >> >> > END # Layer
>> >> >> > _______________________________________________
>> >> >> > mapserver-users mailing list
>> >> >> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
