[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Tue Aug 13 09:08:28 PDT 2013
I'm using spatialite 4.1.1,
so use ogr to access the db.
LAYER
NAME "rt_topogr.50k.etichette.topon_idro_50k"
STATUS OFF
EXTENT 1554750.74 4678325.52 1771722.76 4924791.90
TYPE LINE
CONNECTIONTYPE OGR
CONNECTION "/path-to-spatialite/zz_topografica.sqlite"
DATA "select PK_UID_2, TOPO_OK, GEOMETRY from topon_idro_50k"
PROJECTION
"+init=epsg:3003 +towgs84=0,0,0,0,0,0,0"
END
METADATA
"wms_title" "topon_idro_50k"
"wms_extent" "1554750.74 4678325.52 1771722.76 4924791.90"
END
LABELCACHE ON
MAXSCALEDENOM 60100
MINSCALEDENOM 1
CLASS
NAME ''
MAXSCALEDENOM 60100
MINSCALEDENOM 1
LABEL
TEXT '[TOPO_OK]'
COLOR 0 85 255
OUTLINECOLOR 212 255 255
OUTLINEWIDTH 1
MAXSCALEDENOM 60100
MINSCALEDENOM 40100
FONT "LiberationSans-Regular"
TYPE truetype
SIZE 7
ANGLE FOLLOW
OFFSET 15 99
POSITION auto
PRIORITY 10
MAXOVERLAPANGLE 180.0
BUFFER 1
FORCE OFF
PARTIALS FALSE
MINDISTANCE 200
END
LABEL
TEXT '[TOPO_OK]'
COLOR 0 85 255
OUTLINEWIDTH 1
MAXSCALEDENOM 40100
MINSCALEDENOM 1
TYPE truetype
SIZE 9
ANGLE FOLLOW
OFFSET 15 99
POSITION auto
PRIORITY 10
BUFFER 1
FORCE OFF
PARTIALS FALSE
MINDISTANCE 200
END
END
END
2013/8/13 thomas bonfort <thomas.bonfort at gmail.com>
> there's something strange in your error message... the
> singleSidedBuffer stuff is in GEOS, and should have nothing to do in
> msOGRFileNextShape. post your whole mapfile layer.
> On 13 August 2013 17:42, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > I tested trasforming the multilinestring dataset in a linestring dataset
> but
> > the error is still here.
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'rt_topogr.50k.etichette.topon_idro_50k'.
> > msOGRFileNextShape(): OGR error. IllegalArgumentException:
> > BufferBuilder::bufferLineSingleSided only accept linestrings
> > So it is not really due to a multilinestring vs linestring question.
> > The quest carry on.
> > 2013/8/13 Andrea Peri <aperi2007 at gmail.com>
> >> Hi,
> >> Try.ing to set a label on a MULTILINESTRING dataset.
> >> I set a label with Follow capability.
> >> ANGLE FOLLOW
> >> But I'm having this error:
> >> Is the Follow compatible with a MultiLinestring dataset or need only
> >> simple linestrings ?
> >> Thx,
> >> Andrea Peri
> >> qwerty àèìòù
> > Andrea Peri
> > qwerty àèìòù
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130813/9a060a4b/attachment-0001.html>
