[mapserver-users] Angle Follow will accept only simple linestring don't MultiLinestring ?
Andrea Peri
aperi2007 at gmail.com
Wed Aug 14 02:21:07 PDT 2013
(sorry, my previous response was cancelled , so I resend after remove the
unuseful parts)
It work without any error.
This is the layer I try to use:
LAYER
NAME "multiline"
TYPE LINE
STATUS OFF
EXTENT 1660351.00 4458445.22 1866743.13 4960849.91
FEATURE
WKT "MULTILINESTRING((1662120.546188 4858603.677291, 1662738.746295
4858875.082216, 1663854.522097 4858618.755342, 1664779.309249
4858638.85941, 1665116.052396 4858342.3244, 1665136.156465
4858035.737355),(1660351.388159 4859814.947419, 1661959.71364
4857844.748704, 1663678.611497 4857724.124293, 1663869.600148
4858136.257698, 1664392.30593 4858085.997526, 1664703.918992
4857452.719368, 1668141.714707 4857613.551916),(1662112.755029
4859495.405004, 1662172.424828 4859710.216279, 1662357.401204
4859984.697353, 1662411.104022 4860175.640708, 1662345.467244
4860318.848225, 1662172.424828 4860473.989701, 1662178.391808
4860670.900037, 1662321.599324 4860796.206614, 1662619.948317
4860849.909432, 1662888.462411 4860837.975473, 1663174.877444
4860611.230238, 1663222.613283 4860384.485003, 1663145.042545
4860247.244467, 1662977.967109 4860056.301111, 1662769.122814
4859841.489836, 1662709.453015 4859680.38138, 1662810.891673
4859435.735206, 1663091.339726 4859250.75883, 1663371.78778 4859137.386213,
1663813.344289 4859143.353192, 1663992.353685 4859256.72581, 1664093.792343
4859513.305944, 1664028.155564 4859829.555876, 1663765.60845
4860038.400171, 1663664.169793 4860193.541648, 1663652.235833
4860390.451983, 1663771.57543 4860545.593459, 1664081.858383
4860599.296278, 1664410.042275 4860581.395339, 1664779.995027
4860402.385943, 1664988.839322 4860133.871849, 1665078.34402
4859919.060574, 1665114.145899 4859644.579501, 1665114.145899
4859423.801246, 1665132.046838 4859214.956951, 1664947.070463
4859077.716414, 1664947.070463 4858862.905139, 1665263.320395
4858725.664602, 1665615.372207 4858731.631582, 1665764.546703
4858916.607958, 1665830.183482 4859214.956951, 1665824.216502
4859567.008762, 1665728.744824 4859925.027554, 1665639.240126
4860223.376547, 1665633.273147 4860503.8246, 1665716.810865 4860670.900037,
1665961.457039 4860760.404734, 1666253.839052 4860760.404734,
1666492.518246 4860617.197218, 1666659.593682 4860408.352923, 1666743.1314
4860098.06997, 1666713.296501 4859811.654937, 1666635.725763
4859638.612521, 1666474.617307 4859519.272924, 1666295.607911
4859465.570105, 1666229.971132 4859435.735206, 1665979.357978
4859262.69279, 1666009.192878 4859065.782454, 1666301.574891
4858886.773058, 1666546.221065 4858862.905139, 1666623.791803
4858707.763663, 1666576.055964 4858516.820307, 1666176.268314
4858445.216549))"
END #FEATURE
LABELCACHE on
CLASS
STYLE
COLOR 200 200 200
OUTLINECOLOR 0 255 0
END
LABEL
TEXT 'BLAH BLAH'
COLOR 0 85 255
OUTLINECOLOR 212 255 255
OUTLINEWIDTH 1
FONT "LiberationSans-Regular"
#FONT "Calibri"
TYPE truetype
SIZE 9
ANGLE FOLLOW
OFFSET 15 99
POSITION auto
PRIORITY 10
MAXOVERLAPANGLE 180.0
BUFFER 1
FORCE OFF
PARTIALS FALSE
MINDISTANCE 200
END
END #CLASS
END
2013/8/14 thomas bonfort <thomas.bonfort at gmail.com>
> what happens if you use an inline wkt feature of type MULTILINESTRING ?
> On 14 August 2013 10:47, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > I do other tests.
> > Using instead of a spatialite, a shapefile.
> > And accessing it using ogr or using ogr driver.
> > I see the error trigger when use spatialite or shapefile accessed using
> the
> > OGR driver.
> > Instead it don't trigger when use a directly defined Feature or the
> > mapserver direct shapefile driver.
> > Regards,
> > Andrea.
> > Andrea Peri
> > qwerty àèìòù
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130814/71260cac/attachment.html>
