[mapserver-users] ScribeUI: Possible segmentation fault on Ubuntu 12.04
Jessica Lapointe
jlapointe at mapgears.com
Fri Aug 16 07:20:26 PDT 2013
Hi Luis,
There shouldn't be a need for a new alias. What does your
runserver.wsgi and config.py files look like ? Do you access the app
from localhost/ScribeUI or another url ?
Thanks,
Jessica
On Fri, Aug 16, 2013 at 8:26 AM, Luís de Sousa
<luis.a.de.sousa at gmail.com> wrote:
> Hi again Jessica,
> After a second restart the server seems to be back to normal and I can now
> load the main ScribeUI page. That was a good tip, thanks.
> Unfortunately ScribeUI is trying to load a heap of assets from
> localhost/static, which does not exist at this stage. Should I map an alias
> from there to /opt/ScribeUI/application/static?
> Thanks.
> View this message in context: http://osgeo-org.1560.x6.nabble.com/ScribeUI-Possible-segmentation-fault-on-Ubuntu-12-04-tp5072423p5072841.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
