[mapserver-users] MapServer query template questions - shpmidx, shpmidy
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Aug 21 07:33:46 PDT 2013
1) layer source projection,
2) yes, use shpxy tag w/projection argument. You must define the layer projection,
3) yes
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] on behalf of Mark Volz [MarkVolz at co.lyon.mn.us]
Sent: Wednesday, August 21, 2013 8:04 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] MapServer query template questions - shpmidx, shpmidy
Hello,
1) I was not entirely clear as to if shpmidx, shpmidy, and other MapServer query functions return coordinates in the source projection or map projection. Which is correct?
2) Is there an (easy) way to get the coordinates represented in latitude and longitude similar to how map geometry will return both [mapx] and [maplon]?
3) I assume that we can control the number of decimal places returned similar to [item name="AcresDeed" precision=2] is that correct?
Thanks
Mark Volz, GISP
GIS Specialist
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
