[mapserver-users] ScribeUI: Possible segmentation fault on Ubuntu 12.04
Jessica Lapointe
jlapointe at mapgears.com
Wed Aug 21 12:45:29 PDT 2013
Hi Luis,
I pushed a new version of the app that should fix the problem. You
will get the update by doing git checkout v0.1.2
You won't need to do any changes to your config files, just checking
out the version will do the trick.
Thank you,
Jessica
On Wed, Aug 21, 2013 at 10:14 AM, Jessica Lapointe
<jlapointe at mapgears.com> wrote:
> Hi Luis,
> I was finally able to reproduce your problem. For now, you should
> access your scribeUI application using : http://localhost/ScribeUI/
> The trailing slash at the end is very important. I am currently
> looking for a way to adjust the configuration so that both url work.
> What happens here is that since the alias scribeui refers to a python
> file, apache will not treat it as a directory unless the trailing
> slash is present.
> I'll keep you updated and will edit the installation instructions for
> the app once I find a fix for this.
> Thanks a lot,
> Jessica
> On Tue, Aug 20, 2013 at 3:40 AM, Luís de Sousa
> <luis.a.de.sousa at gmail.com> wrote:
>> On 19 August 2013 16:16, Jessica Lapointe <jlapointe at mapgears.com> wrote:
>>> Hi Luis,
>>> You are right that the url should be localhost/ScribeUI/static.
>>> In your config.py file, this ip = "0.0.0.0" should be the domain you
>>> access the app with, in your case, it should be ip = "localhost"
>> Hi again Jessica,
>> I tried with "localhost" and "localhost/ScribeUI", but in both cases it
>> tries to load the css and js files from "localhost/static".
>> Thanks,
>> Luís
