[mapserver-users] Cluster with shapefile doesn't show all colums in GetFeatureInfo
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Aug 22 00:48:43 PDT 2013
Hello,
My mapfile is not correct, as we can't get attributes in cluster object from
several feature but this problem occurs also for feature which are not
clustered.
For example, this class has the same "problem", but it seems logical to me.
CLASS
NAME "test2"
EXPRESSION ('[FAMILLE_IC]' eq 'IN' AND [PRECISION]=0 AND '[SEVESO]'
eq 'AS')
STYLE
SYMBOL "usine"
SIZE 40
OFFSET 0 -14
END
END
Regards,
Y.
Le jeudi 22 août 2013 09:33:58 Yves Jacolin a écrit :
> Hello,
> I would like to confirm a bug using cluster feature with shapefile data
> source. When a GetFeatureInfo request is made, we only get attribute which
> are used in CLASS object. Here is my mapfile:
> LAYER # début de la couche
> NAME "test"
> DATA test
> TEMPLATE "ttt.html"
> STATUS ON
> TYPE POINT
> EXTENT -173678 1652366 1470310 2709215
> PROJECTION
> "init=epsg:27572"
> END
> METADATA
> "wms_title" "test"
> "wms_srs" "EPSG:2154"
> "wms_include_items"
> "FAMILLE_IC,PRECISION,SEVESO,EPSG,NOM_ETBT,CODE_POSTA"
> "wms_getfeatureinfo_formatlist" "application/vnd.ogc.gml"
> END
> CLUSTER
> MAXDISTANCE 0.2
> REGION 'ellipse'
> END
> PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
> LABELITEM "Cluster:FeatureCount"
> CLASSITEM "Cluster:FeatureCount"
> CLASS
> NAME "test1"
> EXPRESSION ("[Cluster:FeatureCount]" != "1" AND [PRECISION]=0)
> STYLE
> SYMBOL 'centroide'
> SIZE 35
> END
> LABEL
> FONT "arial"
> TYPE TRUETYPE
> POSITION CC
> SIZE 12
> COLOR 0 0 0
> OUTLINECOLOR 250 250 250
> END
> END
> END
> In this example only PRECISION attribute will be displayed in the
> GetFeatureInfo request.
> As github is down currently I can't check issues, sorry if it already known.
> Does someone could confirm this?
> I am using MapServer version 6.2.1.
> Thanks,
> Yves
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43 (new)
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
