[mapserver-users] cgi variable substituition in DATA statement
thomas bonfort
thomas.bonfort at gmail.com
Thu Aug 22 23:32:32 PDT 2013
yes, that's it. the substitutions only work for the mapserver CGI, not
mapscripts. if you're using mapscript, you can manipulate your mapfile
directly.
thomas
On 23 August 2013 04:41, Peter Freimuth <freimuth69 at gmail.com> wrote:
> Hi,
> i will do so on Monday. Is it possible that the fact that we use a tiny map
> script wrapper to avoid the map file in the url have something to do with
> it.
> By the way i tried the leaving away of the single ' ' already but it just
> fails again because the parameter name doesn't get replaced. Thanks for all
> of your hints.
> Just to complete the circumstances. The map file uses the include mechanism
> to get the layer definitions and the layer which needs the substitutions is
> only referenced by a raster layer as an tile index. Don't know if this have
> something to do with it. If i use static values everything is working fine.
> Kind regards,
> Peter Freimuth
> On 2013-08-22, at 3:17 AM, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> Peter,
> can you email me your full mapfile, with the snippets you provided I
> can't see anything wrong and would therefore need to see any
> side-effects from the rest of the mapfile, and/or run it through a
> debugger to see where it's failing.
> thomas
> On 21 August 2013 01:26, Peter Freimuth <freimuth69 at gmail.com> wrote:
> Hi,
> i am trying to get the dynamic variable substitution work on Mapserver
> 6.3dev but somehow it does'nt work as it worked before and as documented.
> When i execute
> http://10.10.4.18/cgi-bin/LI_USA-MT.cgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=48.046271,-115.929840,48.198407,-115.666914&CRS=EPSG:4326&WIDTH=1647&HEIGHT=953&LAYERS=data_view&STYLES=&FORMAT=image/png&DPI=96&TRANSPARENT=TRUE&STARTDATE=2011-01-01&ENDDATE=2013-09-01
> or
> I get an error in
> msDrawMap(): Image handling error. Failed to draw layer named 'data_view'.
> msPostGISLayerWhichShapes(): Query error. Error executing query: ERROR:
> invalid input syntax for type date: "%STARTDATE%"
> LINE 8: ... (((acquisition_date >= date_trunc('day',date '%STARTDAT...
> So the substitution does not happen or the default is not applied.
> Any hint on what i am doing wrong would be great.
> See below the components from the mapfile:
> MAP
> # Start of web interface definition
> DATAPATTERN '^[a-zA-Z0-9\-\_\,]+$'
> WEB
> IMAGEPATH "/mnt/mapserver/mapserver_wms/geocloud_config/image_path"
> METADATA
> 'PRODUCTID_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
> 'default_PRODUCTID' '1234567'
> 'CONTRACTIDS_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
> 'default_CONTRACT_IDS' '0000'
> 'STARTDATE_validation_pattern'
> '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
> 'default_STARTDATE' '2011-01-01'
> 'ENDDATE_validation_pattern'
> 'default_END_DATE' '2013-09-01'
> END
> VALIDATION
> 'PRODUCTID' '^[a-zA-Z0-9\-\_\,]+$'
> 'CONTRACTIDS' '^[a-zA-Z0-9\-\_\,]+$'
> 'STARTDATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
> 'ENDDATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
> END
> END
> LAYER
> # this is the tileindex that aggregates the single image products
> together and makes them accessible for the RASTER LAYER "data_view" and
> "data_raw" for rendering
> NAME "data_idx"
> STATUS ON
> DEBUG 5
> UNITS dd
> TYPE POLYGON
> EXTENT -116.364631680367 44.1932837062986 -103.698350095065
> 49.1892799088128
> PROCESSING "CLOSE_CONNECTION=DEFER"
> CONNECTIONTYPE POSTGIS
> CONNECTION "user=***** password=***** dbname=***** host='*****'
> port=5432"
> DATA "wkb_geom FROM (SELECT t1.* FROM (SELECT re3aip.cat_id as
> archived_in_archiving_identifier, ico.image_id, ico.acquisition_date,
> re3aip.tile_id,
> ico.product_provider_image_identifier, re3aip.ohs_order_id,
> re3aip.imagetake_cat_id, ico.epsg_code,
> re3aip.ohs_contract_id, ico.service_name,
> ico.footprint_poly::geometry as wkb_geom, ico.image_location,
> ico.vrt_location
> FROM ows.imagepool_catalogue_ows ico
> JOIN ows.re_l3a_imagepool re3aip ON (re3aip.image_id=ico.image_id)
> WHERE ico.service_name in ('LI_USA-MT') AND
> (((acquisition_date >= date_trunc('day',date '%STARTDATE%') AND
> acquisition_date < date_trunc('day',date '%ENDDATE%') + interval '1 day')))
> AND
> re3aip.ohs_contract_id in ('%CONTRACTID%')
> ) t1
> LEFT OUTER JOIN
> (SELECT ico.image_id, ico.acquisition_date, re3aip.tile_id
> '%STARTDATE%') AND
> AND
> ) t2
> ON
> t1.tile_id = t2.tile_id AND
> ((t1.acquisition_date < t2.acquisition_date) OR
> (t1.acquisition_date = t2.acquisition_date AND t1.image_id < t2.image_id))
> WHERE t2.tile_id is NULL
> ORDER BY t1.ohs_contract_id, t1.tile_id
> ) foo USING UNIQUE image_id USING
> SRID=4326"
> #FILTER ( '[product_provider_image_identifier]'='%PRODUCTID%')
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "ows_title" "Data Index"
> "ows_extent" "-116.364631680367 44.1932837062986
> -103.698350095065 49.1892799088128"
> #'PRODUCTID_validation_pattern' '^[a-zA-Z0-9\-\_\,]+$'
> #'default_PRODUCTID' '1234567'
> 'default_CONTRACTIDS' '0000'
> 'default_ENDDATE' '2013-09-01'
> #disable explicitly everything that shall not be supported for
> this Layer
> "wms_enable_request" "!GetCapabilities !GetMap
> !GetLegendgraphic"
> "wcs_enable_request" "!GetCapabilities !GetCoverage
> !DescribeCoverage"
> "wfs_enable_request" "!GetCapabilities !GetFeature
> !DescribeFeatureType"
> END
> VALIDATION
> 'CONTRACT_IDS' '^[a-zA-Z0-9\-\_\,]+$'
> 'END_DATE' '^([0-9]{4})-([0-9]{2})-([0-9]{2})$'
> END
> END
> END
> mapserver-users at lists.osgeo.org
