[mapserver-users] Draw PHP labels
Michael McInnis
mmcinnis59 at msn.com
Wed Aug 28 13:51:41 PDT 2013
Thanks for the suggestion.
Actually, my problem was in the font and size definitions.
Once I happened upon those assignments (below in the // Label section)
my label text magically appeared.
You would think the text would default to something like everything else.
Thank you for all the feedback!
// Layer 3 airports--------------------------------------------------------
// Point Symbol
$nSymbolId = ms_newSymbolObj($oMap, "circle");
$oSymbol = $oMap->getsymbolobjectbyid($nSymbolId);
$oSymbol->set("type", MS_SYMBOL_ELLIPSE);
$oSymbol->set("filled", MS_TRUE);
$aPoints[0] = 1;
$aPoints[1] = 1;
$oSymbol->setpoints($aPoints);
// Layer
$oLayerAirports = ms_newLayerObj($oMap);
$oLayerAirports->setConnectionType(MS_POSTGIS);
$oLayerAirports->set("name", "airports");
$oLayerAirports->set("type", MS_LAYER_POINT); # This is crucial
//$oLayerAirports->set("type", MS_LAYER_ANNOTATION); # This is crucial
$oLayerAirports->set("status", MS_DEFAULT);
$oLayerAirports->set("labelitem", "icao");
//$oLayerAirports->set("classitem", "MyAirports");
$oLayerAirports->set("connection", "host=xxx port=xxx dbname=xxx user=xxx password=xxx");
$oLayerAirports->set("data", "geom From (select a.icao, geom From airports a left join airportdata e on a.icao = e.icao where e.icao Is Not Null) as subquery using unique icao using srid=4326");
// Class with Labels
$oAirportsClass = ms_newClassObj($oLayerAirports);
$oAirportsClass->set("name","MyAirports");
// Style
$airportsStyle = ms_newStyleObj($oAirportsClass);
$airportsStyle->color->setRGB(255, 22, 22);
$airportsStyle->set("symbolname", "circle");
$airportsStyle->set("size", "3");
// Label
$oAirportsClass->label->color->setRGB(0,0,0);
$oAirportsClass->label->set("font", "verdana");
$oAirportsClass->label->set("size", "tiny");
$oAirportsClass->label->set("position", MS_AUTO);
$oAirportsClass->label->set("antialias", MS_TRUE);
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130828/21712d9b/attachment.html>
