[mapserver-users] Orientation of vector symbols on a LINE
Havard Tveite
havard.tveite at umb.no
Thu Aug 29 00:05:53 PDT 2013
The implementation of GAP has been fixed (center to center
distance between symbols), and so has the calculation of
symbol height.
I guess that the following should work:
STYLE
SYMBOL "wavy_line"
WIDTH 1
SIZE 2
GAP -6
COLOR 0 0 0
END
Since you have y values from -1 to 1, and x values between 0
and 6, the ratio between the height of your symbol and the
length is 2 / 6. The ratio between size and gap should be the
same to make the the line continuous.
Håvard
On 8/29/2013 1:31 AM, TC Haddad wrote:
> Hello, I'm trying to understand symbol orientation and (maybe) use of ANCHORPOINT on a line in Mapserver 6.2.
> The vector symbol that I have been using for line cartography in MapServer 6.0.3 is below, and I am trying to get the same effect in Mapserver 6.2.1.
> SYMBOL
> NAME "wavy_line"
> TYPE vector
> POINTS
> 0 0
> 1 1
> 2 1
> 3 0
> 4 -1
> 5 -1
> 6 0
> END
> END
> Display in Mapserver 6.0.3:
> https://dl.dropboxusercontent.com/u/42845001/mapserver6.0.3.png
> Relevant Style bloc from Mapserver 6.0.3:
> STYLE
> SYMBOL "wavy_line"
> WIDTH 1
> SIZE 2
> GAP -1
> COLOR 0 0 0
> END
> This did not translate directly to Mapserver 6.2.1, but I came close with this:
> STYLE
> SYMBOL "wavy_line"
> WIDTH 1
> SIZE 4
> GAP 6
> COLOR 0 0 0
> END
> which produced this:
> https://dl.dropboxusercontent.com/u/42845001/mapserver6.2.1.png
> Obviously I am missing something about how to get the symbol to orient along the line, I played with ANCHORPOINT as that was new in 6.2 and it seemed like the default of 0.5 0.5 should work for my symbol, but I also tried several other value combinations and it seemed to merely shift the symbol around laterally, while maintaining an upright orientation.
> So I'm a bit confused on how to achieve the original effect, (behavior something like the equivalent of FOLLOW for Labels). Any pointers appreciated...
> mapserver-users at lists.osgeo.org
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
