[mapserver-users] Projections and raster files
Fawcett, David (MNIT)
David.Fawcett at state.mn.us
Thu Aug 29 08:43:14 PDT 2013
David,
Take a look at the map extent and units. They should be the units used by your output spatial reference system.
In your current map file, you have DD for the units, for 3857, they should be meters. You will also want to express your extent in 3857 coords.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David Power
Sent: Thursday, August 29, 2013 10:01 AM
To: MapserverList OSGEO
Subject: [mapserver-users] Projections and raster files
Hello,
I have a number of geotiffs which are currently using epsg:4326 and I would like to output a region using epsg:3857.
I am new to mapserver but from what I have read the way achieve this is by setting the projection of the map to epsg:3857 and the layer to epsg:4326.
When I set the projections to the same value I get the output I expect without a problem, if I set the projections to different values I do not get an error but the output is blank.
To make life more complicated I am using mapscript via the Java swig interface, the version of mapserver I am using is mapserver 6.1.2.1 which I built from source.
If anybody has any advice I would be most grateful.
David
gdalinfo gives the following information about one of the files:
Driver: GTiff/GeoTIFF
Files: globcover_n10e005.tif
Size is 7200, 7200
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (5.000000000000000,9.999999999999615)
Pixel Size = (0.000138888888889,-0.000138888888889)
Metadata:
DataType=Generic
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 5.0000000, 10.0000000) ( 5d 0'0.00"E, 10d 0'0.00"N)
Lower Left ( 5.0000000, 9.0000000) ( 5d 0'0.00"E, 9d 0'0.00"N)
Upper Right ( 6.0000000, 10.0000000) ( 6d 0'0.00"E, 10d 0'0.00"N)
Lower Right ( 6.0000000, 9.0000000) ( 6d 0'0.00"E, 9d 0'0.00"N)
Center ( 5.5000000, 9.5000000) ( 5d30'0.00"E, 9d30'0.00"N)
Band 1 Block=7200x128 Type=Byte, ColorInterp=Gray
NoData Value=0
The map file is built programmatically, the following is the result of saving the map object to file:
MAP
EXTENT 5 9.9 5.1 10
IMAGETYPE "png"
NAME "blank"
SIZE 800 800
STATUS ON
UNITS DD
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGB
TRANSPARENT FALSE
END # OUTPUTFORMAT
PROJECTION
"init=epsg:3857"
END # PROJECTION
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STATUS OFF
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS OFF
STYLE HILITE
END # QUERYMAP
SCALEBAR
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
END # WEB
LAYER
DATA "/home/leftworker/data/landcover/lefttiles/n10/globcover_n10e005.tif"
NAME "n10e005"
PROJECTION
"init=epsg:4326"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE RASTER
UNITS DD
END # LAYER
END # MAP
Dr David J Power
Research Officer
Department of Computer Science
University of Oxford
tel: 01865 283670
email: David.Power at cs.ox.ac.uk<mailto:David.Power at cs.ox.ac.uk>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20130829/9246c4ac/attachment.html>
