[mapserver-users] MapCahe question -- Caching the first couple of zoom levels
thomas bonfort
thomas.bonfort at gmail.com
Mon Dec 2 05:53:53 PST 2013
James and others,
I have also had requests for this off-list, but am somewhat weary to
implement this. Firstly, this goes against the concept that mapcache
is a *cache*, although I do clearly understand why/when this could be
needed. Secondly, there's a whole lot of logic that treats the
"metatile" problem that would need to be overridden or worked around
in that case (as we would not want to send a full metatile request to
the WMS server, but only the extent for a single tile. This would need
to be accounted for rather early as multiple incoming requests are
synchronised/paused while waiting for the same metatile).
This is an issue that doesn't scratch any of my itches, so I will
probably not be adding it without any incentive, even more so that
there are some workarounds available as pointed out by Andreas and
Armin. I would also add that rather than implementing this
straightforwardly, I would prefer having the possibility of having
multiple caches per tileset, depending on the zoom level, so that e.g.
high zoom level tiles could be stored to a volatile memcache backend
that automatically does the pruning, thus avoiding the metatile issues
completely.
regards,
thomas
On 24 November 2013 16:57, James_in_Utah <James.Evans at hill.af.mil> wrote:
> Hi,
> I'm trying to configure mapcache (from latest dev version of MS4W) and would
> like to cache the first couple of zoom levels of a very large set of USDA
> NAIP imagery. I've tried using the minzoom and maxzoom tags in the tileset,
> like this:
> <grid restricted_extent="-180 -90 180 90" minzoom="1"
> maxzoom="6">WGS84</grid>
> but once I zoom below the maxzoom value I get no imagery. I would like it
> to send the request to the source if it is beyond the maxzoom value. Is
> there a way to do this?
> Thanks,
> James
> View this message in context: http://osgeo-org.1560.x6.nabble.com/MapCahe-question-Caching-the-first-couple-of-zoom-levels-tp5090882.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
